not charging right
ok guys ive put a total of 60 miles on my truck for break in. the problem im having is it aint charging woth a damn. two new interstate batteries and new ground cables and power between cables. the truck made 14 volts before disasembling with higher rpms now it drops below the first dash mark, any ideas
Not sure on this but it is worth a shot, I had the same problem on my 79 gmc after I put it back together and no charge, it ended up being the signal wire coming from the battery to tell the alternator to charge, good luck and hope you get it fixed.
ok guys i made a jumper wire from the rear of the alterbnator to the battery and that was the problem, its getting the full 14+ volts now. i just need to figure out whick wire aint conected. I COUNT MY TRUCK ON FIRE
dont use 18 guage wire as a jumper when doing this proceduere it ends up badly
ok i traced the wires tomight and there was a little fuse in the fuse block that is shot i think that might be the problem
dont use 18 guage wire as a jumper when doing this proceduere it ends up badly---AutoMerged DoublePost---
Last edited by 94cummins12v; Mar 25, 2009 at 11:10 PM. Reason: Automerged Doublepost
its all wraped in loom, everything looks ok, it may be a few things, touching wires together, grounding out that stud on the oil filter housing when tightening the bolts, if it pops it again then i ll start replacing more wires, i still cant belive i cought the old girl on fire though
