06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
Need help with boost guages
Old Mar 19, 2009 | 06:13 PM
HeavyChevyDMAX's Avatar
Default Need help with boost guages
I want to put in a boost guage in my 07 LBZ. What needs to be done to put it in?
Old Mar 19, 2009 | 07:09 PM
dozerboy's Avatar
Drill and tap a hole in the intake run tube, wire the light in the gauge to the dimer switch. in short
Old Mar 19, 2009 | 07:23 PM
2500HeavyDuty's Avatar
x2
you can remove the intake run tube and drill and tap it. wiring the power for the light to the dimmer power source wont hurt it
heres a pic i stole from KC i circles the intake tube that has the boost tap on it, you can see it its the little brass booger on there
Old Mar 19, 2009 | 08:10 PM
Oilfield_Mafia's Avatar
Yep.. thats my pic Danny stole.. I can get you a better one if you need bud. Just disconect the IC boot from the bottom so all your shavings fall right out onto the ground..
Old Mar 20, 2009 | 07:08 PM
dozerboy's Avatar
I stuffed a rag in mine too. The shavings don't fall out that well if you use tapping oil.
Old Mar 20, 2009 | 10:30 PM
ScrmnEagle's Avatar
In addition to these steps, you could also use a battery operated vacuum to collect other shavings. JMO.
Old Mar 20, 2009 | 10:36 PM
Probably not.. I didnt think about using oil since it was by hand.. and its Cast..
But shoving a rag in it would work as well
Old Mar 30, 2009 | 08:14 PM
ok cool thanks guys...
hey oilfield can you get a closer pic for me by any chance??
Old Mar 31, 2009 | 09:14 AM
Sure will.. I'll go snap one here in about 10 minutes..
Old Mar 31, 2009 | 04:22 PM
redneckbuckeye's Avatar
Here is a hepful link for the wiring and complete install.
Diesel Place
and this one
http://www.dieselplace.com/forum/sho...ht=hoot+method
casper83
Jun 5, 2015 04:35 PM
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
