EGR Valve Cleaning
Old Jun 1, 2007 | 04:05 PM
CHenry's Avatar
Vegistrokin Bombardier
Default EGR Valve Cleaning
Thought i would post this for any of you 6.0 PSD guys who might in the future be dealing with the dreaded EGR issue. This valve will get sooted up and not open and close right causing your rig to run poorly. The dealers have been told to stop replacing them and just to pull them and clean them so for you DIYers, this can be done in 20 minutes in your driveway.
First of all locate the EGR (shown in the pic.)
The red lines are not stock so don't get confused, these are water/Meth injection lines
1)unplug the wires.
2)remove 2 10 mm bolts
3)This is the fun part. I use a large set of water pump pliers, crawl up on my knees and position myself above the valve, get ahold with the pliers on the metal housing on the valve and pull up while i twist and wiggle (I don't twist and wigle, i twist and wiggle the EGR valve, but you knew that right?).
It takes a fair amount of strength so if you are not able to get it, maybe a buddy can help. Once you think it won't come out, keep trying and all the sudden it pops loose.
Take the valve and spray it with a can of carberator cleaner or brake clean - use a toothbrush to help get it clean.
4)Theres 2 O-rings that you can replace before you reinstall it IF they look bad, i didn't replace mine and haven't had a problem. Now reverse the procedure and reinstall it.
If you have a EGR code in the PCM you will have to get that cleared but she should run better now.
Old Jun 8, 2007 | 02:06 PM
JON's Avatar
JON
Member
Default Nice right up Clay
Let me add a lil something to this. Clay is 110% accurate on the fact Ford wants us to clean the egr's now. But let me add my 2 cents. This very rarely works. 9 out of 10 I cleaned ever cleared up and the ones that did took a crap within 100 miles again. So long story short, you can clean it but you'll need a new one eventually. I'm hoping the aftermarket jumps on these things someday.
Old Jun 8, 2007 | 02:49 PM
CHenry's Avatar
I cleaned mine once about 10k miles ago and have had no more codes since then. Although maybe i'm the lucky one.
Not saying your wrong at all but it has worked well for me.
Jon is the one i believe who told me originally how to do this.
Old Jun 8, 2007 | 02:53 PM
JON's Avatar
JON
Member
Default Yeah
I'm not gonna say it doesnt work but it is a **** poor valve setup that I hope we can get fixed without bypassing it.
Old Jul 1, 2007 | 09:16 PM
Patrick@DPP's Avatar
One way to fix this is to get custom tuning that disables the EGR, and then pull the up-pipe and block this headache off. I have actually turned my truck back to stock with the EGR blocked and had no problems no CEL, but it is common to get a CEL without disabling. I guess I'm lucky.
AutoMerged DoublePost
Nice right up Clay.
Jon, do they use this same crap on the 6.4l? We havent had one in to play with yet.
Last edited by Patrick@DPP; Jul 1, 2007 at 09:16 PM. Reason: Automerged Doublepost
Old Jul 1, 2007 | 10:58 PM
CHenry's Avatar
Hey Pat, Glad to see you on here! Hows Larry? Get his a$$ on here too.
I do want to invest in a tuner for this very reason soon.
Old Jul 1, 2007 | 11:06 PM
Everything is great! I finally have Larry's help full time, so things are alot better now. Its summer time so things are crazy of course.
Take care Clay, call us some time.
Old Jul 1, 2007 | 11:18 PM
CHenry's Avatar
You needed that...you stay pretty busy by yourself! Glad to here the duo is bach together full time!
Old Nov 26, 2007 | 06:49 AM
Mdub707's Avatar
Thanks for the write-up and picture to go with it! Pretty simple, but I would have never known if you didn't post. Also does anyone think maybe with some preventative cleaning during maintenance intervals, that it would prevent problems later down the road with the EGR?
Old Aug 3, 2008 | 09:07 AM
bigD12's Avatar
dose anyone know where they sell the egr block off kit.
bigd12
