leaking from the water in fuel sensor / check valve
Old Mar 14, 2009 | 12:07 PM
bb84ss454's Avatar
Default leaking from the water in fuel sensor / check valve
I was driving my truck a couple of weeks ago, which I don't do often, and I stopped for fuel and noticed a strong diesel smell. I put some in and headded for home. I didn't think much about it until today. I started it and noticed fuel dropping on the ground. It's leaking from the water in fuel sensor / check valve. I pushed it up and down a couple of times and started the truck back up and it still leaks. Can it be fixed or do I need to replace it?
Old Mar 14, 2009 | 11:51 PM
wildbill's Avatar
Sounds like a new o-ring?? See if there is anyway of getting it apart.
Old Mar 22, 2009 | 10:01 AM
MRaynor's Avatar
Update please.
Old Mar 22, 2009 | 10:45 AM
Whit's Avatar
Site Mascot
I think yer talkin bout 2 different things here
water in fuel sensor is in the side of the fuel filter housing and yes it does have a O-ring so this could be bad
there is also the canister drain valve to drain out any water accumilation you may have...........this has o-rings too so if the leak is here check it out, also if you look at it the lever doesnt actuate the valve stem very well....you may need to just push down on the valve stem...not the actuator
Old Mar 25, 2009 | 05:07 AM
wildbill's Avatar
Update please
Old Mar 28, 2009 | 09:35 AM
wildbill's Avatar
Any updates??
Old Apr 4, 2009 | 10:30 AM
wildbill's Avatar
Closing due to a one time post.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
yams
Dec 7, 2014 12:51 PM
