Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
10K Mod
Old May 31, 2007 | 02:07 PM
DB Admin's Avatar
Banned
Default 10K Mod
You guys still do this?
Old May 31, 2007 | 02:13 PM
CHenry's Avatar
Vegistrokin Bombardier
i think some of the 7.3 guys still do. It jacks with the timing and supposedy gives better response on the throttle or something... but makes it idle rough i have heard.
Old May 31, 2007 | 02:38 PM
DBogo's Avatar
i got the adjustable one with an on off switch off of ebay when i had my powerstroke, its like $100 bucks from some guy zelectronics i think, it worked good and was nice because you could turn it off
Old May 31, 2007 | 03:08 PM
CraigPSD's Avatar
They are a waste of time... Basically they bump up the ICP so the computer throws more fuel. There have been many variations including 10K, 18K, the adjustable mentioned above, and of course the overly expensive Edge EZ. All of these can be accomplished with about $1.50 worth of parts and resistors from Radio Shack. I never could under stand why someone would spend more than $10 on a premade one. But lots of people do!
Nowadays we can increase so many parameters (including ICP) in tuning on a chip, that you will see less and less 10K mods.
Craig
Old May 31, 2007 | 06:45 PM
DB Admin's Avatar
Banned
Actually I have done quite a few of these , I was Checking the response ,,,
Go to radio shack and get a strip of 10K Resistors ,
Take a 6 inch piece of telephone wire and pull all 4 of the wires out ,,, strip 1 inch off either side of 2 of the wires , solider the wires on either side of the resister to lengthen it tape up with electrical tape ,
unplug the ICP connector and look at it it will have like 2 eyes and a mouth stick one end in the right eye and the other in the mouth Then plug it back in and your done ,
Start it up if it lopes like a huge cam you have the thing in the left eye ,
If its idles a bit higher than normal you did it right this increases your Injectors Fuel Pressures ,
The Only code i have seen was an Over Boost code as the more fuel is spooling the charger better
I stacked with a Superchips BAD IDEA truck ran like crap dont stack a 10k mod
Thats it Bomb your ride for a quarter
DM
Old Jul 4, 2007 | 09:04 AM
Cerebus's Avatar
I ran the adjustable 10k for about 6 months. It's a noticable difference over stock and worth the money to build yourself. I was stupid and bought one of the $100 jobbies ...would have been better off putting the $100 towards a real chip.
Old Jul 8, 2007 | 07:47 PM
dozerboy's Avatar
Anyone got some pics of this I have a friend that likes cheap mods. He ain't the internet type.
Old Aug 1, 2007 | 01:57 PM
OneBadBia's Avatar
I'm a girl!
My husband did this on his truck and a friends truck it is very easy to do but with one bad slip you could be spending alot of money. You need to make sure you have a very very steady hand.
It made a slight change in both trucks but nothing huge. Still for as cheap as it is why not do it.
Old Aug 1, 2007 | 02:05 PM
2141pete's Avatar
never heard of this before, but not much of a powerstroke guy. What exactly is it for? Is it just a cheap way to more fuel?
Old Aug 1, 2007 | 10:01 PM
DBogo's Avatar
it tricks the ICP (injection pressure control sensor) to thinking that the pressure to the injectors is low so it bumps it up and pushes in a little bit more fuel, all it is is a 10k resistor that you put on one of the wires on the ICP
