Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
OEM blowoff valve and electronically controlled wastegate?
Old Mar 11, 2009 | 09:40 AM
Begle1's Avatar
Default OEM blowoff valve and electronically controlled wastegate?
Did any Ford Diesel, older Ford Diesel's in particular, have a blowoff valve or electronically controlled wastegate from the factory?
The answer would be "no", right?
Old Mar 11, 2009 | 11:17 AM
Benjamin's Avatar
Bombardier
IIRC no is the answer. i believe that dodge had an actual electronically controlled wastegate and the powerstrokes had the VGT or VNT that was electronically controlled, so not really a wastegate...... and i've never seen on a diesel a factory BOV.... gassers yes diesel no....
stkdram55's Avatar
yes i think the answer is no, never heard of one being on a ford OEM
Old Mar 23, 2009 | 10:48 AM
CSIPSD's Avatar
The wastegate on the 7.3 is electronically controlled but boost actuate. A electric signal opens a small orifice to bleed pressure to a canister that then opens the wastegate.
So the awnser is yes.
Old Mar 23, 2009 | 11:25 AM
94cummins12v's Avatar
thats not a blowoff valve though,
Old Mar 23, 2009 | 01:35 PM
CSIPSD's Avatar
Correct, but he also asked about a wastegate...
Old Mar 27, 2009 | 11:10 PM
robammerman's Avatar
If you're referring to the OBS, the answer is no. The same goes for the newer 7.3 vans. Just don't confuse the EBPV for a wastegate. It's that oil operated valve on the back of the exhaust housing. That just helps the engine warm up in cold weather.
