still having problems with my 2000 powerstroke
ok a while back i posted about a vibration that my truck was having
well i took to the shop to have this guy fix it and he said a wire coming from the
IDM module was coroded and that the number 8 injector was bad so he put new injector and fixed the wire and it still feels like it might be missing and when i driving in overdrive and give it some gas and let off and slow down it smokes for a few minutes and stops i dont know what the hell is goin on please give ideas thanks
Are you smoking from the draft tube or when you remove the oil fill cap? Puffing smoke out here could be a scored cylinder.If the cylinder was scored it will knock real loud and engine will miss.Check oil level then make sure you are not making oil. If over full fuel dilution will show up on the dip stick from not firing.Take your truck out and run it down road make some boost and get it warm then see if it still has a miss.Could be ring needs to seat again.
Tylerbuckley
9
Sep 21, 2015 08:24 PM
cjgregory
Mar 31, 2015 01:45 PM
Nov 16, 2014 05:14 AM
Oct 30, 2014 08:10 AM
Blue Briar
Oct 5, 2014 08:23 AM
