Cummins hopping!!! need help!!
Old Mar 4, 2009 | 10:01 AM
masonobrien's Avatar
Default Cummins hopping!!! need help!!
I have an 07 cummins and love it but, whenever you hit a bump around 70mph it starts to hop. it hops so bad that it throws cups out of my cup holder. any ideas on how to stop it?
Old Mar 4, 2009 | 12:51 PM
wildbill's Avatar
Is it more of an up and down, or does the truck shake back and forth?? If back and forth, it's what they call death wobble. Need to replace pretty much most of the front end.
Old Mar 4, 2009 | 03:49 PM
wildcat's Avatar
There is a TSB out to fix/upgrade the steering to the tie rod drag link style VS. the current inverted y.
There is ALSO a TSB out to fix some of the replacement steering upgrades!
Old Mar 6, 2009 | 09:45 AM
soupdog06's Avatar
mine did that, replaced shocks first,,still the same, then track bar and tie rods still the same, put on different tires, wahlah, fixed
Old Mar 6, 2009 | 10:59 PM
wyoranch's Avatar
Yeah, sounds like the track bar. My 03 did the same thing. Turns out the rubber bushing on the track bar was worn out. You can get the bushing at NAPA for $13. Easy fix. Just curious, shouldnt it still be under warranty?
Old Mar 7, 2009 | 08:49 PM
wildbill's Avatar
Any updates??
Old Mar 11, 2009 | 05:45 PM
wildbill's Avatar
Any luck??
Old Mar 12, 2009 | 12:09 PM
80powerwagon's Avatar
Does the truck have a lift kit I know there were some issues with kits. If not let us know what you fine out
Old Mar 14, 2009 | 11:49 PM
wildbill's Avatar
Closing due to last activity: 03-04-2009 09:01 AM
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
