Cummins heater grid in a 7.3 PSD
Old Mar 3, 2009 | 02:57 AM
Chief Engineer's Avatar
Default Cummins heater grid in a 7.3 PSD
Anybody out there seen or heard of installing a Cummins starting heater grid into a 7.3 PSD. My wife's 01 is the most cold blooded vehicle I've ever owned. At 40 F, if it's not plugged in, I usually only have a 50/50 shot of getting it started. I've got twin 900 CCA batteries in there and the glow plugs are fine, even running synthetic for a little less friction. I'm sure it can be done, just hoping somebody else may have blazed the trail....
Old Mar 3, 2009 | 03:09 AM
Mr. Miyagi's Avatar
The California trucks have a intake heating element on them that runs off a relay mounted where the glow plug relay normally sits on the 49 state emission trucks.
It would be a relatively simple mod to perform to get an actual heating element in the system.
Old Mar 3, 2009 | 03:34 PM
so, I'm assuming they've got a similar set up in the intake elbow like a Cummins to allow for the grid heater?
Old Mar 4, 2009 | 01:45 AM
Mr. Miyagi's Avatar
It's a rather small element that screws into the elbow/Y...looks similar to a cross between a block heater element and a temp sending unit.
A person could probably have good luck with adding an actual grid assembly in a custom intake system, eg. like a modified Tymar or similar.
I don't know how much start assistance the CA heating element provides--IIRC it's primary purpose is to help eliminate cold idle smoke.
D K
May 17, 2015 11:27 AM
dodge2014
Apr 16, 2015 08:54 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
Dunn
99-03 7.3L Performance
Oct 26, 2014 01:44 PM
