Dynatrack ProSteer Ball Joints
Old Feb 26, 2009 | 03:34 AM
FormerVendor
Default Dynatrack ProSteer Ball Joints
Has anyone tried these new Ball Joints yet or heard of anyone using them??
From what I have found there $250 per side. But they are rebuildable.
New Dynatrac Heavy Duty ProSteer Ball Joint | Sand Addiction Magazine
Luke
Old Feb 26, 2009 | 06:54 AM
Uncle Bubba's Avatar
The article says they aren't available yet and the Dynatrac site site doesn't list em at all that I can find. They say they are rebuildable in the field, I gotta see this. I wanna know how they're gonna pull those hubs in the field.
I would also be interested in seeing just what is rebuildable about them. A ball joint is nothin but a bock of steel, what are you gonna rebuild. Sounds like just a lot a hype over nothin to me but I may change my mind if they would give enough info to answer some questions.
Old Feb 26, 2009 | 01:31 PM
FormerVendor
Called them today.... Still in the testing stage and not going to be available until June 09. Around $250 per side. Rebuild kits will be less than buying new factory ball joints.
Old Feb 26, 2009 | 01:38 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
But who buys Factory anything?
Get some Moog joints and be done with them.
Old Feb 26, 2009 | 01:51 PM
FormerVendor
The key here is that they are claiming they can be rebuilt. And rebuilt for cheaper than Moog Ball Joints.
Luke
Old Mar 6, 2009 | 09:06 AM
triton's Avatar
NADM Member
Luke, not sure if you know of them but, Carli makes some sweet ball joints. Only the uppers are available at the moment though
Dodge Ram HD Upper Ball Joints - Dodge Ram Suspension System Components
Old Mar 6, 2009 | 10:19 AM
MotorOilMcCall's Avatar
As far as rebuildable, I'm guessing they use a Brass joint for the actual socket. If it gets to the point its too loose, you pull a castle nut with a spanner wrench and replace the whole socket. Kinda like with CTM Joints, instead of using needle bearings, they use a brass bushing.
Old Mar 6, 2009 | 10:46 AM
spoolinaround's Avatar
there is a one page ad in the new diesel power about them and a real stout track bar they are going to make aswell, I figured $100 a joint
Old Mar 6, 2009 | 01:09 PM
FormerVendor
$250 per Side for the Dynatrack Ball Joints
Old Mar 6, 2009 | 01:36 PM
So $125... I paid about $90 for the MOOG's... If these were out I'd have spent the extra dough.
