racing tips
Old Feb 24, 2009 | 07:55 PM
dhardy1357's Avatar
Default racing tips
ok, so i hate to sound like such a newb, but i guess i am so...i was wandering if anyone had any tips on racing a duramax. 4wd boost launches? not using first gear? i have an automatic but should you shift manually 1 thru 3 then to drive. and overdrive off, right?
Old Feb 24, 2009 | 08:40 PM
Oilfield_Mafia's Avatar
I wouldn't recommend a 4wd Boosted launch without some HD Tie Rods or at least some Tie Rod Sleeves.. You can make your front tires point towards each other pretty easily. Just turn tow/haul on and drop your t-bars and tire pressure in the rear..
Untill you get a trans and some sleeves, you can tear alot of stuff up.
Old Feb 24, 2009 | 08:48 PM
Rttoys's Avatar
Like this??
Old Feb 24, 2009 | 08:51 PM
Rttoys's Avatar
Once you get HD tie rods and a nice programmer: Put it in Tow/Haul mode and 4wd, power brake to 2200rpm, light turns green- let off the brake and run full throttle.
and your off like a prom dress.....
Old Feb 24, 2009 | 08:58 PM
TCU Fan's Avatar
Aaron
Originally Posted by Rttoys
Like this??
That guy was trying to tear hi truck up that day. Nice looking truck though.
IIRC Danny has a launch video of his truck doing the same thing.
Old Feb 26, 2009 | 10:47 PM
hondarider552's Avatar
not using first gear ie 2nd gear start will allow you to get traction better, and launch at a higher rpm and boost psi.....BUT...
It will eat your converter, weither be stock or built, plus its kinda hard to drive on the return roads..
Old Feb 27, 2009 | 07:31 PM
2500HeavyDuty's Avatar
you will deffinately eat up the stock convertor when launching in 2nd gear using efi live tcm tuning. and even more when staging with the t/h on.
first thing would to get some tie rod sleeves cause you can bend them tie rods easily. I dont use t/h when im taking off from a dead stop, only when i racing from a roll. make sure to drop your t bars to where the cv´s are flat.
if your going to be doing it alot some cognito braces and tie rod sleeves will be dandy.
Old Mar 1, 2009 | 08:02 AM
Randy07GMAX's Avatar
I agree with the sleeves, I launch in 4 wd with stock trans in t/h at about 2-2100. I raced quite abit last yr. with no problems with trans, and racing with a dynoed 470 tune. Not saying everyones trans will last but it can be done. I also pull with the same tune an 14.5 ft. enclosed trailer and have 60K on truck., with no problems (Knock on wood).
Old Mar 1, 2009 | 08:17 AM
dhardy1357's Avatar
yeah, unfortunately my trans didnt hold up. even with 130 tune. tranny and tie rods and sleeves will be next
Old Mar 1, 2009 | 08:27 AM
That sucks. Ya, the sleeves are a must for 4wd launchs. I didn't have them at the first couple times at the track, and was running 285's and the wheels would toe in bad. I went back down to 265's and stock wheels and sleeves and made a HUGE diff on my 60 ft. Good luck..
