to much blowby
Old Feb 22, 2009 | 02:31 PM
HAYMAFIA's Avatar
Default to much blowby
does anybody sell a kit that separates the oil coming out of my blowby tube and put it back in the engine i know the logical thing to do is rebuild but it still runs great and still pulls 40,000 70 miles an hour so i hate to retire it
Old Feb 22, 2009 | 03:34 PM
MotorOilMcCall's Avatar
Its normal for an engine to blow oil out the blowby, if you hate the dripping there are kits out there to collect the oil drippings. Its basically a box with a breather filter on the top, and the blowby runs into it. It'd be easy enough to make if you had a welder and a bit of scrap steel layin around.
Old Feb 22, 2009 | 03:45 PM
HAYMAFIA's Avatar
its pretty excessive i drove 160 miles and used two gallons of 50 weight oil
Old Feb 22, 2009 | 04:07 PM
Beets's Avatar
that sounds like you may have other probelms
Old Feb 22, 2009 | 04:14 PM
HAYMAFIA's Avatar
is there a screen or filter connected to the blowby tube
Old Feb 22, 2009 | 05:30 PM
Not that I know of. If you're using that much oil you have something burned up or a bad ring, or the easiest one to check, a bad Vacuum pump. If the vacuum pump is bad it'll pressurize the block. Do you have a vacuum leak somewhere? Does the heat only blow on defrost?
If its vacuum I'd be surprised, thats an awful lot of oil to go through. You could always compression test the motor and see if its indeed a bad cylinder or ring, but the keystone rings in these things shouldn't go bad.
Old Feb 22, 2009 | 05:37 PM
HAYMAFIA's Avatar
the blowby is consistent no puffing like a hole n piston but im just hoping for the best
