6.4 Owners - IN HERE - Injector Replacement Customer Satisfaction Program
Customer Satisfaction 09B08
Involves replacing certain injectors on your truck, based on build date/serial number.
If any of you wish to determine if your vehicle is covered under this program, post the vin here (DO NOT PM ME) and I will check and see if you're involved.
Hope i can be of help to some here.
You should be receiving a letter in the mail regarding this shortly, also, if your vehicle is involved in the campaign.
I got the letter, and it said it's a no-charge
HI big-angry-hillbilly, FORD wants to reprogram my truck's pcm, tcm, & ic SHOULD I LET THEM MESS WITH MY TRUCK, cause it's running good, but I'm only getting 12.4 to 14.4 MPG ???
Last edited by gunman41mag; Feb 21, 2009 at 02:01 PM. Reason: Automerged Doublepost
How about this one -
1FTWW31R18EC40888
Thanks in advance
hey gunman if your not having any problems with it do let them reprogram - mine was the best truck I ever owned until they reprogramed it the first time - they have tried SEVERAL new ones since then and none have fixed it - when I got mine it never said "Cleaning Exhaust Filter" at all in the first 30,000 miles - they reprogrammed it and said that the original program would not allow it to show that - showing it had nothing to do with the price of eggs but after is when it started running like **** - they call me every three or four weeks saying "We got another one to try, bring it back up" - I'm tired of bein the sucker here
1FTWW31R18EC40888
Thanks in advance
1FTWW31R18EC40888
Thanks in advance
I don't see that reprogramming will get you any better fuel mileage - yours is getting about average for the '08s - big-angry-hillbilly says his is getting better than that but he is the only one - hopefully he can give you good advice
I get good economy mainly based on driving habits, REALLY good fuel, additives, and a bit of a tuning issue.
I've got some fuel trim issues and need to replace a couple injectors...I'm only averaging 18-19mpg a tank right now.
1FTWW31R18EC40888: No matches found in injector replacement table
1FTSW31R18EC69256: No matches found in injector replacement table
You know, a tuning 'issue'
I plan on switching to a spartan tuner with the DPF delete after tax time.
Sunoco Gold diesel fuel, PM-17-A and PM-17-B fuel additives.
Plus I drive under 60mph most of the time, as well as have very few stops on my commute.
I plan on switching to a spartan tuner with the DPF delete after tax time.Sunoco Gold diesel fuel, PM-17-A and PM-17-B fuel additives.
