VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
Anybody Know Where The Fuel Screw Is On A 1.5L
Old May 24, 2007 | 11:54 PM
Monster Truck's Avatar
Default Anybody Know Where The Fuel Screw Is On A 1.5L
Looking for the fuel screw on a 81 1.5l IDI motor,anybody have any pics of its location?
Old May 25, 2007 | 08:20 AM
Buckshotmckee's Avatar
Sma't Alec!
If I recall it's on the back of the pump. I may be wrong. It's been a while since I messed with one. I'll be back @ work on Tuesday were I can access VW service net. If you can wait.
Tye
Old Dec 15, 2007 | 12:07 AM
VWZZUK's Avatar
The fuel screw on the Bosch Injection pump (1.5, 1.6 and 1.9's) is at the back of the pump on the top cap. You'll see a long horizontal threaded screw with a standard screwdriver slot in the end. The screw has a factory spot welded stainless steel collar on it seated next to a 13mm nut so you can't ajust it.
If you want to adjust it, take off the stainless steel collar( grind it off just to the threads and take a die and clean the threads up) and that will let you adjust it. Going in increases your fuel. Going out decreases your fuel. Do it an 1/8th a turn at a time until you see black smoke when you accellerate. Then back it off some. Be careful. You do not want to get too much fuel or you will heat up too much.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
