91 12valve tranny problems
i just built the tranny and it is doing the same thing it did before i rebuilt it.its fine from dead stop through overdrive but when your runnin in od it seems like it is suckin air or somenthing.it loses the power like the motor is kinda free revin.i changed the throttle positioning sensor and the speed sensor on the tail shaft. do you think its the tv cable please help thanks rich
Have you checked the TPS Sensor?
http://www.dodgeram.org/tech/transmi...TPS_adjust.htm
edit: I read your post a second time and saw that you already replaced it.
