CRAZY STARTER PROB -MAKIN ME NUTS!!
Old Feb 15, 2009 | 10:28 AM
LONESTAR's Avatar
Default CRAZY STARTER PROB -MAKIN ME NUTS!!
I have a 1994 Chevy K2500 with a 6.5 turbo that has got me stumped. I had changed the fuel, air, and oil filters in this truck and the next day the wife needed to go to the store wbout 9 miles from the house. the truck ran fine to the store. She then called me to say that it wouldn't start. I asked all the normal questions about did you do this and that and she said yes so we called a tow truck to bring it home. This truck has a remote start on it also. The problem is when you turn the key on and wait for the glow plug lite to go off and try to crank it there is nothing,nada,zilch. No starter engagement at all. I have checked fuses, power to the starter itself, wiring. If anybody has anything please relieve my insanity.
Old Feb 15, 2009 | 10:37 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
do you have any acc lights when you turn key on
Old Feb 15, 2009 | 12:07 PM
wildbill's Avatar
Might be the circuit block on the steering column went bad. Be a small rod going into it.
Old Feb 15, 2009 | 06:32 PM
LONESTAR's Avatar
Thanks Pap & WildBill for the info. I have gone through all the checks from the ignition switch to the starter and found that it was the starter after all. Changed it and back on the road. Thanks for lookin at my post.
Old Feb 15, 2009 | 09:32 PM
Rttoys's Avatar
What was your voltage at the purple wire at the starter, when cranking??
The alarm (starter interupt) could give you a voltage drop causing the starter to not enguage. A new starter, being new, will make it work just fine, but later, it won't be fine. Seen it too many times, just ask'n.
Old Feb 16, 2009 | 11:10 PM
LONESTAR's Avatar
I'll be sure and check that out RT. Thanks again for the info. I really needed it. What a great place this is.
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
