Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Amount of 2 stroke per tank?
Old Feb 5, 2009 | 10:10 AM
CumminsRig's Avatar
Default Amount of 2 stroke per tank?
I have been doing some reading about this and still not sure what is what. I have an 07 5.9l and was wanting to try some 2 stroke oil with my fuel. My question is how much 2 stroke oil should I put in? Thanks for any advice.
Old Feb 5, 2009 | 10:22 AM
01quadcab's Avatar
1oz per gallon maybe a little less. But your truck was built for this fuel
Old Feb 5, 2009 | 10:31 AM
K50's Avatar
K50
1:200 ratio is the commonly accepted ratio all across the board; i.e. for any diesel engine. They're even running 1:200 in new Mercedes diesel cars over in Europe.
Old Feb 5, 2009 | 12:22 PM
CumminsRig's Avatar
What do mean it was built for this fuel? Would you not run anything for an additive? Thanks for your help.
Old Feb 5, 2009 | 02:18 PM
srountreeoo7's Avatar
He means the '07 and newer were designed to run on Ulsd. I personally use an additive. Mostly Power service
Old Feb 5, 2009 | 03:18 PM
Snowman's Avatar
MR.3K
A really good additive that i find works very very well is Howes. My dad drives big truck and i work as a diesel mechanic and the majority of the drivers run Howes. And now its designed for ULSD. Its also 25% stronger now then the previous year, made to mix with ULSD. Try it, you might like it, i do!!
Old Feb 5, 2009 | 04:16 PM
01quadcab's Avatar
if you still have your smog etc on there then it has a chance of causing issues thats all. but if you don't it should work fine.
Old Feb 5, 2009 | 04:30 PM
mikmaze's Avatar
I use one quart per fillup, I tend to go about 6 tanks, then skip one so as not to continue creeping up on the concentration level in the tank. to that I also ad 1/2 bottle ps white bottle winter, grey summer.
Old Feb 6, 2009 | 12:00 AM
CumminsRig's Avatar
I have the 5.9 not the 6.7 so I don't have all the smog crap to deal with. Thanks for the input guys I think I shoud be good to run a qaurt for a full tank. Where can you find the Howes? I have never seen this stuff.
Old Feb 6, 2009 | 12:13 AM
Uncle Bubba's Avatar
They sell Howes about anyplace that sells diesel fuel and any farm store or hardware store. I'll also second the recommendation for it.
My personal experience with 2 stroke oil, and I know it's not the common thing to happen but it did to me. This stuff was the best penetrating oil I ever found. I jumped on the bandwagon usin it way back when when all this came out. Took me a few years to get my fuel line connections to stay tight after I quite usin it. Since then I've started usin it for penetrating oil around the barn and it does work well.
