06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
exhaust question
Old May 21, 2007 | 11:24 AM
rnhmac1016's Avatar
Default exhaust question
I have 06 GMC LBZ with a deablo sport tuner, I pull a lot of heavy equipment. I want to upgrade the exhaust system but not sure what would be best, cat in or out and 4 in or 5 in, can anyone help
Old May 21, 2007 | 12:15 PM
Whit's Avatar
Site Mascot
I am a Cummins dude but will assume that this knowlege will apply to a Max as well...the less the resistence the better.........someone back me up on this for the D-max though
here is some exhaust information in general that is very interestimg
https://www.dieselbombers.com/showth...ht=pipe+dreams
Old May 21, 2007 | 12:45 PM
ndurbin's Avatar
I'd get rid of the CAT unless you are in an area that requires visual inspections or opacity tests for emissions. 4" works just fine until you start pushing over 500hp at the wheels.
Old May 21, 2007 | 07:04 PM
duramaxdavid's Avatar
I went with 4" fromt he turbo back(so they call it). I would go catless
Old May 21, 2007 | 07:30 PM
dozerboy's Avatar
The biggest EGT drop will be from a Catback ya gain a little more losing the cat and if you block off the EGR, but you could set a CEL more likely if you do the cat and you will set a code if you block off the EGR. I would just cut out what ever you want muffler/cat and get some pipe from a muffler shop. The codes can be avoided with a Finger stick and removing anything other then the muffler could cause you some trouble at the dealer.
Old May 25, 2007 | 04:53 PM
redneckbuckeye's Avatar
I went with 4" straight pipe egr blocked and fingered. It runs wel, without a load and ppe hot+2 level 3 at wide open my egts only go to about 800*.
Old May 28, 2007 | 07:59 AM
GmcLbz's Avatar
Site Sponsor - Upstate Diesel Performance
Where do you have your pyro?
Old May 28, 2007 | 08:41 AM
Whit's Avatar
Site Mascot
800 would be a post turbo mount
Old May 28, 2007 | 07:29 PM
It is mounted pre turbo,this is a pic http://dieselplace.com/forum/uploads/CF8_installed.jpg
Old May 28, 2007 | 10:44 PM
dozerboy's Avatar
I think you have something wrong with it then because 800* is way to low. I wouldn't be surprised if you shouldn't be able to bury at 1600* pyro with the Hot. How many HP is level 3 and what are your cruising temps?
