Dodge Diesel Tech Articles All Years of Cummins Tech Talk
ABS issues
Old Jan 29, 2009 | 04:33 PM
farm boy's Avatar
Default ABS issues
Im trying to locate my dignostic connector so that i can check my truck. my abs light is on and i need to figure it out before something breaks or malfunction.
Old Jan 29, 2009 | 04:39 PM
stkdram55's Avatar
you dont have an OBDII port like the newer trucks, you'll have to do the key cycle trick...on off on off on and then count the flashes like it will blink 2 times pause 3 times pause then 5 times and that is code 235...im pretty sure thats how it works because your truck doesnt have a digital odometer does it??
Old Jan 29, 2009 | 04:42 PM
big_dog37074's Avatar
yes thats how thay work. count the flashes
Old Jan 29, 2009 | 05:04 PM
farm boy's Avatar
hey thanks guys it has been bothering me for a while now. ill look at that later.
Old Jan 29, 2009 | 05:11 PM
Benjamin's Avatar
Bombardier
A guy from another forum sent me this back when i was having ABS issues......
If your ABS light and brake light come on, in most cases it's probably your Rear Wheel Speed Sensor (RWSS). This sensor is on top of the rear differential.
This sensor is controlled by a "exciter ring" that is interupted by the teeth on the ring sending a variable voltage signal to the computer depending on vehicle speed. small metal shavings can cause it to fail over time. The most common symptoms of the switch's failure are bad speedometer readings and tripping the RWAL computer located under the center of the dash.
Other obvious things can also trip the computer such as:
1. bad pads, shoes, calipers, wheel cylinders.
2. bad fuses.
3. poor connections or broken and/or chaffed wire.
Once you have detemined that none of the above exist, you can try a system reset buy pulling the abs fuse and/or pulling negative battery terminals for 30 sec or so.
If the lights come back, the next thing to try is reading the RWAL fault codes.
To read the codes on 96 and older trucks:
1. turn key to the "on" position.
2. for just a second, ground pin # 13 on the diagnostic plug located on the knee bolster (#13 is a black wire, it's the 4th from right bottom row).
watch your ABS/Brake light for codes.
start counting with the first long flash, end with last short flash.
there are only 13 codes.
1. Not used.
2. open isolation valve wiring or bad control module.
3. open dump valve wiring or bad contol module.
4. closed rwal switch.
5. not used 4wd. over 16 dump pulses in 2wd.
6. erratic speed sensor reading. (most common)
7. electronic control module fuse pellet open, isolation output missing, or valve wiring shorted to ground.
8. dump output missing or valve wiring shorted to ground.
9. speed sensor wire resistance/ high reading.
10. speed sensor wire resistance/ low reading.
11. brake switch always on, RWAL light comes on over 40mph.
12. not used.
13. electronic control module phase lock loop failure.
14. electronic control module program check failure.
15. electronic control module RAM falure.
mine was a code 10. it was a break in the molded section of wire off the RWSS.
*On 97-98.5 12V models, you will end up at the dealer to get the ABS codes.
Hope this helps, and good luck!
Old Jan 29, 2009 | 05:21 PM
stkdram55's Avatar
the year of trucks he is talking about though are the late 12v's that have a data port under the dash
Old Jan 29, 2009 | 05:25 PM
Benjamin's Avatar
Bombardier
i know this. These instructions are for that era of truck. mine is a 96 and has the data port.
Old Jan 29, 2009 | 05:27 PM
stkdram55's Avatar
my bad thanks for bolding it for us idiots that cant read
Old Jan 29, 2009 | 05:30 PM
farm boy's Avatar
my truck is a 95
what is the knee bolster?
Old Jan 29, 2009 | 06:06 PM
Benjamin's Avatar
Bombardier
it is the piece of plastic below the steering wheel. it will be almost inline with the accelerator pedal where the dash ends going down from the steering wheel.
