ticking?
Old Jan 26, 2009 | 12:25 AM
94cummins12v's Avatar
Default ticking?
ok guys i was hauling 4 long track sleds up the pass this weekend. trying to keep my egts below 1200*. i forgot to take the cardboard out of my grill and she over headed. truck completly shut off until she cooled. after that ran great the rest of the weekend. tonight i noticed it has a really load tick almost like it needs a valve adjustment again. could that be the cause? also there is now oil coming out of the blow by tube not alot few drops here and there, never was. whats everyones thoughts. truck still has full power and responsiveness.
oh also when she over heated the oild was boiling no doubt smokin like something else. #4 valve cover not sealing completly smoke was coming out of there. i pulled the oil lines off the turbo to make sure bearings wernt fried, thank god there fine
Last edited by 94cummins12v; Jan 26, 2009 at 12:25 AM. Reason: Automerged Doublepost
Old Jan 26, 2009 | 12:58 AM
Cummins97's Avatar
boiling oil? Surely that's not good for the bearings!
I would definitely change that oil out now since it's been that hot.
Old Jan 26, 2009 | 01:00 AM
im going to tomarrow, dont know about boiling but you couldnt touch the oil filter thats hot
Old Jan 26, 2009 | 01:06 AM
farm boy's Avatar
ya that is really hot
Old Jan 26, 2009 | 11:34 AM
im going to go ahead and give it another valave adjustment just for kicks see if that helps but its driving me nuts
Old Jan 26, 2009 | 11:46 AM
GRI's Avatar
GRI
what was your oil pressure?
Old Jan 26, 2009 | 08:23 PM
about 50psi
Old Jan 26, 2009 | 08:29 PM
Cummins97's Avatar
oil change and valve adjustment not help?
Old Jan 28, 2009 | 09:01 PM
im going to do the valves tonight and oil change tomarrow since it cant hurt anything to do it
anyone have any other opinions on this like why there is now oil coming out of my blow by tube?
ok now its more of a damn knocking rather than a ticking still havent done the oil or valves yet but that will be todays projects, could it be a posible as "spun a rod bearing" and how much of a pain in the *** is that going to be
ok i changed the oil today and its not as loud as it was, called the local diesel performance shop and he thinks its the lift pump that has gone out were the rod contacts the cam? the knocking in my opinion sounds the same on top and on both sides, any input would be great
could it posibly be the p-7100
we found out today what the deal is, it is coming from the #5 cylander its either the wrist pin and bearing or piston because of the amount of blowby
Last edited by 94cummins12v; Jan 28, 2009 at 09:01 PM. Reason: Automerged Doublepost
Old Jan 28, 2009 | 09:26 PM
Ouch
