bumpin fuel in my 98 12v ?s any help?
Old Jan 20, 2009 | 06:55 PM
stinky-D's Avatar
Default anybody know turbos?
this guy has a borg warner from a dt466 international that he wants to mod for my truck. is it safe and worth it? im tight on cash right now
Old Jan 20, 2009 | 08:15 PM
cummins freak's Avatar
just push it toward the fender a little it will pivot and then you can pull the AFC off.
Old Jan 20, 2009 | 08:45 PM
stinky-D's Avatar
after i grind my plate to a #100 do i move the afc forward? or leave it in stock position?
Old Jan 20, 2009 | 09:23 PM
whats your tranny like?
Old Jan 20, 2009 | 10:19 PM
usmcbay's Avatar
THROW IT AWAY... Get you a cable shut off - just to be like a tractor. Works for me. My FSO was not getting into full position and when I took it off I realized how choked down I was because of it. That's just my experience...
Old Jan 20, 2009 | 10:46 PM
stinky-D's Avatar
well i just got the truck a week ago and all i know is he pulled a ball hitch toy hauler it has 190,000 miles and the fluid looks a little redish gray im changing it tomorrow
what are the indications of a tranny going bad?
Old Jan 20, 2009 | 10:49 PM
slipping and such
Old Jan 20, 2009 | 11:01 PM
stinky-D's Avatar
i dont have slip but is it common for the od to shift a little ruff when i take od off to slow down well at least not as smooth shift as it automaticly does
Old Jan 20, 2009 | 11:56 PM
if your going to mod it at least get a Valve body and converter that should keep ya happy and safe till you can afford a full tranny
Old Jan 21, 2009 | 07:11 PM
Yellow Yota's Avatar
There's a bolt in the rear end of the bracket that holds the shut off solenoid in place. Just loosen it about a turn and it will pivot real nice and easy like.
If your tranny isn't upgraded with at least a valve body and good converter, you'll be buying a complete trans before long if you get carried away.
It hurts, but $1500 or so now will save you loads in the future.
As far as your AFC question, it all depends on how you have the rest of your truck tuned and what you're looking to accomplish. With stock injectors and turbo, most folks slide the AFC housing all the way forward. Most loosen the starwheel a bit as well. The function of the AFC is to control fueling at no to low boost situations. There's lots of tuning time involved to get one set up perfectly. Remember, too much fuel will put the fire out.
I'd suggest sliding your stock plate and AFC housing forward all the way until you get the tranny beefed up. Adjust the starwheel and smoke screw to your liking. Even with this little bit of modding, you're gonna **** off a stock transmission if you're not careful.
