dodge lift
Old Jan 19, 2009 | 12:17 AM
dan33klein's Avatar
Default dodge lift
hey guys,i got a tuff country 3 inch lift about a week ago. today i went to install the lift when i ran into a problem. when i tried removing the control arms to install the new ones, i could not remove the bolts in the upper control arms. the nuts came off fairly tough, but the bolts would not come out completely. why not? long story short i had to reassemble everything back to stock, and save it for another day.
my friends dad said to put some heat on it,spin the bolt with an impact while beating it will a hammer. if i had to destroy the bolts to get them out i would. i pry could pick some up at my dodge dealer.
any suggestions?
Old Jan 19, 2009 | 12:33 AM
Red_Rattler's Avatar
High Tech Redneck
Why did you post this again?
Old Jan 19, 2009 | 12:41 AM
dan33klein's Avatar
i posted it in the suspension section hoping to get more posts and opinions.
why?
Old Jan 19, 2009 | 12:44 AM
High Tech Redneck
Just curious I didn't see it was in a diff. section. Good luck with it, but it should be just fine if ya get everything good and lubed up.
Old Feb 24, 2009 | 04:15 PM
Silverback's Avatar
Are you saying that they started comming out and wouldn't come out the rest of the way or they won't move at all?
Old Feb 24, 2009 | 06:29 PM
GRI's Avatar
GRI
this is a common problem. I had to cut my bolts on the bottom control arms. be happy it isnt the bottom bolts with the oblong washer. dodge sucked me for 40 bucks for the bolts washers and nuts.
did you try some heat?
Mac1997
Jul 13, 2015 05:08 AM
ctjkelley
Jun 3, 2015 06:01 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
cass_epp
Price Quote - Request A Price
Oct 28, 2014 02:49 AM
