charging
Old Jan 17, 2009 | 07:10 PM
tunip1998's Avatar
Default charging
alt. is good .doesn't charge and no guages work on 98 dodge! Is it the pcm? The only way i get it to charge is by bootlegging the fields which would work but have no guages at all working.
Old Jan 17, 2009 | 08:42 PM
Whit's Avatar
Site Mascot
fuse box and relays??????????
Old Jan 17, 2009 | 09:37 PM
MRaynor's Avatar
We're going to need a little more info. to help you out. When did this start? What seemed to have triggered it?
Old Jan 17, 2009 | 10:41 PM
spoolinaround's Avatar
search back in this section about 6-8 months ago I remember someone else blew something in a 2nd gen and it was a large underhood fuse and knocked out the cluster and the alternator was not charging, maybe not this section but 12v subforum
Old Jan 17, 2009 | 10:54 PM
Red_Rattler's Avatar
High Tech Redneck
Could be pcm since that what regulates the alt output, could be grounds. How did you test the alt?
Old Jan 18, 2009 | 08:14 AM
never2fast's Avatar
crank position sensor? If it goes out, then it wont charge and the computer acts like the truck isn't running. If you have a 12v then you can still drive around with no noticeable differences in power, but if it is 24v then you will definitely notice a difference.
Old Jan 18, 2009 | 08:35 AM
tunip1998's Avatar
all fuses ,relays fine
batteries were changed , cold mornings didn't want to start
it is 24v runs great but won't shift right because of problem
Old Jan 18, 2009 | 08:37 AM
never2fast's Avatar
did it just start out of nowhere, or did you notice the gauges acting up prior to complete failure?
Old Jan 19, 2009 | 07:40 AM
tunip1998's Avatar
out of nowhere the guages were great except for fuel guage
thanks for all the imput .does anyone have adiagram to wire in voltage regulater on this and which one do i get?
Old Jan 19, 2009 | 09:42 AM
GRI's Avatar
GRI
this happened to me. there is a huge fuse called the fuseable link that you should check.
it makes the alternator circuit complete.
