Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
94 PSD won't start
Old Jan 14, 2009 | 08:32 AM
SouthernCummins's Avatar
Default 94 PSD won't start
I just bought a 94 F-250 to drive to work and back. I didn't plug it in last night, and got up this morn, with an outside temp of about 40*. Cycled the key 3 times, tried to start....nothing, white smoke. Cycled the key 5 more times, turned it over....nothing white smoke again. Just turns over and just wont fire off. Im fairly knowledgeable on PSD....But wanted to get someone elses opinion....Is this my glow plugs? Or simply just from not pluging it in? Thanks for any input.
Tanner
Old Jan 14, 2009 | 03:09 PM
gunman41mag's Avatar
Moderator
I would have the glow-plugs checked, cause my 1999 F-250 would start in 40 degree weather !!!
Old Jan 14, 2009 | 05:41 PM
slowtowpig's Avatar
change the gp relay, there bad about goin out on the older psd's oh and yea you will need to change the gp's in the near future.
Old Jan 19, 2009 | 10:41 PM
wacdeiselperfomance's Avatar
mine is a 99 and i had the same problem i changed my glow plugs butt nothing changed so mine ended up bein the icp sensor its on the top of your valve cover drivers side
Old Mar 3, 2009 | 09:43 PM
chrisdiazmoreno's Avatar
i think you should scan it because you have fuel and compression but some sensor is protecting your engine if you get the code send it i can help you
Old Mar 26, 2009 | 05:38 PM
liftitlly's Avatar
Test your GP relay, then test your glowplugs themselves. More than likely its one of those two. Possible ICP sensor. I have come across bad HPOP causing no cold start, usually that causes no hot start, but its possible for it to cause no cold start. also ether from the previous owner might be a culpret.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
