ABS problems need help ASAP
Old Jan 14, 2009 | 12:03 AM
trailhunter's Avatar
Default ABS problems need help ASAP
The truck is drivable but barly. I had a hole in one of my brake lines wich i fit tonight when i got home. It wont seem to hold pressure now. If i pump the brakes twice it holds enough pressure to stop but the front brakes only work. If i pump the brakes to much the peddle goes rock hard and it takes all my power to stop the truck. I bled the brakes and cycled a big bottle of fluid throw it and the peddle still creaps to the floor until the ABS and (P) e-brake light comes on. Should i take it to a shop and have the full system bled on the machine or is it some thing else. The problem only started when it started leeking brake fluid one the rear line.
Booster?
Master cyl ?
any advice will help
Thanks
Old Jan 14, 2009 | 01:00 AM
jnicewan's Avatar
definately sounds like air, and that can be difficult to bleed out when it has to go through the accumulators/valve etc in the abs system. i have also seen when you lose a particular brake or line it causes the proportioning valve to shift, then if a pocket of air gets in the valve it may not want to reset itself it and that valve has a button on the end you can press and maybe help.
Old Jan 14, 2009 | 08:39 AM
i broke off the bleeeder valve on the rear drives side so i couldnt do a proper bleed, im thinking its the problem
Old Jan 14, 2009 | 10:12 AM
Johnny Cetane's Avatar
Bleed it some more and make sure your rear brakes are adjusted correctly. If you replace the rear wheel cylinders upgrade to the Chevy 1-ton cylinders. You'll stop a ton better.
Old Jan 14, 2009 | 09:03 PM
part number by chance?
Old Jan 17, 2009 | 03:20 PM
wildbill's Avatar
Any updates??
Old Jan 21, 2009 | 10:57 PM
wildbill's Avatar
What's the good word!!
Old Jan 24, 2009 | 01:38 PM
wildbill's Avatar
how goes it
Old Jan 25, 2009 | 03:56 PM
Turbohunter's Avatar
any word?
Old Jan 25, 2009 | 04:14 PM
wildbill's Avatar
Going to close it down for now. Thread starter can reopen.
cjt8569
Sep 29, 2015 06:39 PM
GT_Eleanor
Aug 25, 2015 09:35 AM
willis964x4
9
Aug 22, 2015 12:21 PM
canigeta727
Mar 18, 2015 05:00 PM
ValleyF250
Nov 1, 2014 07:56 PM
