Transfer PUMP Gone
Old May 16, 2007 | 05:15 PM
bway1341's Avatar
Angry Transfer PUMP Gone
I got a problem my transfer pump went out it is on the side of the engine. Tap it a few time it got me home. The new pump is the up grade and it goes in the tank. Is the an bomb up grade I can do. Also is there a way to clear foot prints in the ecm before I go to the dealer to have it fixed under warrnety."give:
Old May 16, 2007 | 07:14 PM
Uncle Bubba's Avatar
Upgraded fuel pump in the tank, tell em thanks but no thanks. Theyare no better then the junk hangin on the side of the motor. When the tank pump screws up, now you have to drop the tank before you can run anything else cause it will slow fuel delivery down. Just upgrade to an afteramarket pump now before it's to late.
The most common options are the Walbro, Holley Blue or Black and the FASS.
As for hiding the fact that you have played with the truck, that all depends on how hard they wanna look. If they wanna play nasty, and they know what they are doing, they will find the tell tale signs. Best bet is to not give them any reason to wanna look.
Old May 16, 2007 | 07:20 PM
bway1341's Avatar
I will even take the velcro off the fuse box where the edge mounts and give it a shoot first
Old May 16, 2007 | 08:47 PM
MRaynor's Avatar
I was just about to call you and see if you made it home. When you clean off the velcro, make sure you get every bit if sticky crap and rinse the engine good so that they won't be able to find where you have been fooling with connectors.
Old May 17, 2007 | 06:35 AM
bway1341's Avatar
Yep we will see if they say my warrnerty is voided can I have them flash it and take it to another dealership. Or is it in the computers that it is voided.
Old May 17, 2007 | 07:28 AM
If they find something of concern they will tag your truck in the dealer computer system. These are the hazards of playin. Most shops won't go through all this trouble without good reason though.
Old May 17, 2007 | 07:51 AM
Whit's Avatar
Site Mascot
the new intank pump will be worse than the old one...dont do it even if its free.....I changed one out for a co-worker and I cant believe how much plastic and junk the thing is......his pressure was terrible and he had no bombs
Old May 17, 2007 | 10:20 AM
Wyatt Earp's Avatar
Do yourself a favour - get a FASS.
Old May 17, 2007 | 10:58 AM
CHenry's Avatar
Vegistrokin Bombardier
I have a FASS on my vegi oil system and its a strong pump...had it apart once and those gears look like they could pump gravel uphill.
Old May 17, 2007 | 12:12 PM
bway1341's Avatar
cool guys thanks will try to get one.
