7.3 engine change question.
Old Jan 13, 2009 | 03:22 AM
tony ramsey's Avatar
Default 7.3 engine change question.
Is it easier to pull the engine and transmission together or engine by it self? It,s 4x4, psd, 6"lift kit,. I have to swap my turbo, oil pan and alternater etc over to the engine that's going in. Any advice is welcomed.
This is my first diesel swap, Is there any gaskets, seals or anything that is best replaced while enginge is out. The enginge going in has 119,00 miles vs 238,000 miles the one coming out. I plan to have the higher milage one rebuilt for mor pulling power. Thanks in advance...tony
Old Jan 13, 2009 | 06:00 AM
wildbill's Avatar
Auto or manual?? Manuals are a PITA when going back in the hole. You have to get the input shaft to line up as well as dowel pins. As far as seals, do the rear main and the front timing cover (harmonic balancer), and any hoses/lines that run around the back of the engine.
Old Jan 13, 2009 | 06:09 AM
powerstroking it up's Avatar
pulling the engine on fords requires the cab to be lifted off. doing it your self is going to be challenging. like this ------->
Old Jan 15, 2009 | 08:01 AM
It,s a automatic, Is it best to lift the frame or can i remove the front grill and pull it that way?
burndiesel
10
Feb 7, 2023 01:15 AM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
boylesjesse
Apr 8, 2015 10:11 PM
GTAYLOR1956
Feb 11, 2015 06:35 AM
krinderhagen
Jan 15, 2015 12:07 AM
