Timbrens
Old May 15, 2007 | 06:11 AM
DBogo's Avatar
Default Timbrens
can anyone give me any info on timbrens, do they work good, anything about them, i cant find anything, alright thanks guys
Old May 15, 2007 | 10:24 AM
Longhorn's Avatar
Have a look here......
http://www.timbren.com/aeon-rubber-springs.htm
When using AEON Hollow Rubber Springs as a supplement to conventional leaf springs, coil springs, torsion bars or air springs, the empty ride is not affected. The AOEN Spring is gradually brought into operation according to the load being applied and progressively increases in proportion to the load being carried. Initial take-up is very smooth and the spring rate increase is progressive, resulting in a greatly improved ride, improved load handling, greater load stability and longer spring life.
Old May 16, 2007 | 07:46 AM
DBogo's Avatar
has anyone here used them?
Old May 16, 2007 | 09:35 AM
GRI's Avatar
GRI
wow those are cool. I wonder what they cost?
Old May 16, 2007 | 09:43 AM
Longhorn's Avatar
I havent used them myself....couple reasons:
I figure if you are having issues with your truck bottoming out then you have some serious suspension issues that I personally dont feel will be helped by rubber blocks. My 06 Mega is a perfect example. I hated the ride in the front, it swayed and bobbed like a 70's muscle car with bad shocks. In the field it bottomed out constantly. I installed a KORE levelling kit and the improvement was out of this world.
Same thing for the rear....To me if you are maxing out you load capacity, to me the best way is to add leafs to your pack, this is very common here for guys that are welders and such...
Now....I have heard from users that are using them, and every one of them swear they are the greastest thing since Kraft Dinner....I am not positive, but I think Duluth Diesel (member) is using them. I am opposed to the CONCEPT only...The users have rated them very highly....They are much cheaper than any kind of suspension upgrade as well.
Old May 16, 2007 | 09:45 AM
GRI's Avatar
GRI
I just called the dealer in Binghamton and they directly bolt in where the stock bumpstops are.
the ones for my 04 CTD were $189.85.
thats not to bad
Old May 16, 2007 | 09:47 AM
GRI's Avatar
GRI
the only problem with add a leafs is that it stiffens an already really stiff suspension which is painful to drive empty.
Old May 16, 2007 | 09:53 AM
Longhorn's Avatar
I agree...What I was refferring to is these guys that are pipeline welders and such that are carrrying a common static load. Talked with one yesterday that has added 2 long leafs which made the truck sit level when loaded with all his gear. The issue now is that the rear sits 4" higher if he unloads which he found out when he unloaded his gear in the garage the other night....And then couldnt fit the truck under the door...
That price doesnt sound too bad though....
Old May 16, 2007 | 10:05 AM
GRI's Avatar
GRI
ok I see that point.
These might be going on my truck. With a full load of firewoodmy truck dips down quite a bit. these would be awesome to make it sit level and improve ride.
Old May 16, 2007 | 10:26 AM
Longhorn's Avatar
Let us know if ya do it. Would be great to have some more information to post from a user.....
Thanks
