Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
35 or 40?
Old Dec 26, 2008 | 02:27 PM
HOTMOPR's Avatar
Default 35 or 40?
I have a slightly damaged 60 mm wheel for my hybrid. It just has a couple small nicks in it. Which would be better for a short while. the stock 56 mm wheel or the slightly nicked 60mm wheel? this is in a twins set-up.
Old Jan 5, 2009 | 07:35 PM
MRaynor's Avatar
Any takers?
Old Jan 5, 2009 | 07:36 PM
DazedandConfused's Avatar
Have any pics to show how bad it is nicked?
Old Jan 6, 2009 | 11:29 PM
spoolinaround's Avatar
well this turbo went for a week with that wheel on it before the new wheel arrived, not the best idea but when your daily driver looses a transmission you got to get to work somehow
Old Jan 7, 2009 | 11:10 AM
HOTMOPR's Avatar
Mine wasnt nearly that bad.. I bought a 64/71-14.. Runnin single now.. I like it. It hits dang hard! Just need a few more PSI..
Old Jan 7, 2009 | 11:15 AM
DB Admin's Avatar
Banned
how did that happen ?
Old Jan 7, 2009 | 11:31 AM
HOTMOPR's Avatar
I dont know how mine got nicked up unless there was some weld dingle ***** in the cold pipe after I built it. not sure..
Old Feb 25, 2009 | 09:18 AM
Deezel Stink3r's Avatar
I wouldn't run this turbo under any circumstances as long as this wheel is changed and new balanced.
The turbo spins up to 150.000 rpm. It will damage your bearing and the complete alignment.
If you have it already replaced, let someone check the balance.
A complete turbo replacement is way more expensive.
