6.5 won't start
Old Dec 25, 2008 | 02:14 PM
pricklypear's Avatar
Default 6.5 won't start
When I bought the truck it started good. After I got it home, I found out the truck had trouble starting if it was shut off for 30 plus minutes. It would start, run a few seconds, and then die. If I held the accelorator down like you would a flooded gas engine, the truck would turn over for a few seconds, start and run forever. If the truck sat for a few hours, it had no problem starting. My wife took the truck and it died a few blocks from our house, and would not start again. I changed the primer pump, and have fuel coming out the bleed valve on the filter, but no fuel coming out when I open the injector lines. It's a 93 6.5 turbo diesel, with a manual pump. Any ideas? Thanks![/I]
Old Dec 25, 2008 | 03:01 PM
wildbill's Avatar
Check for power on both wires on the injector pump. One will be the fuel cut off and the other for the fuel return check valve. If both have power, unplug them, then plug it back in and listen for a click. Probably going to have to do it a couple times. Might be that you crank it over for a few seconds, crack and injector line, then repeat 4 or 5 more times, to re-prime the injector pump.
Old Dec 25, 2008 | 03:32 PM
Man, if you were a girl I would come over and give you a big fat kiss. You really made my day with your excellent advise. My truck is running, and my wife doesn't have to run me around anymore. I hope you are having a great Christmas, because you just turned mine around. Thanks again!!!!
Old Dec 25, 2008 | 03:37 PM
Whit's Avatar
Site Mascot
good to hear ya got er goin man
the kiss thingy made me laugh
Good Job Bill
Old Dec 25, 2008 | 03:41 PM
wildbill's Avatar
Just had to re-prime the injector pump was all then?? A simple handshake is good enough for me!!! You have a merry Christmas to.
Old Jan 16, 2009 | 01:07 AM
hereismylife's Avatar
Now that is funny.
penley`
Jun 7, 2015 04:38 PM
petew
Jun 2, 2015 07:33 AM
flyer
Dec 9, 2014 07:53 AM
bdemutis
Dec 7, 2014 01:36 AM
Daniel Leipart
Oct 6, 2014 08:17 PM
