fuel filter change
Old May 13, 2007 | 06:46 PM
2001shrtbedcummins's Avatar
Default fuel filter change
I've got an idea of how to change the filter...but does anybody have a detailed instructions? Maybe with pictures. 91 D250
Old May 13, 2007 | 09:21 PM
MRaynor's Avatar
I am looking for info for you now Phil, maybe somebody else will chime in too.
Old May 13, 2007 | 09:25 PM
MRaynor's Avatar
OK bud, here is what I found. I will do more searching for you if this doesn't help.
1. Disconnect the wire plug from WIF sensor.
2. Use a small band wrench to loosen it then spin her off.
3. Dispose of the fuel in it.
4. Remove the WIF sensor from the filter.
5. Replace the "O" ring on the sensor with the new one supplied with the new filter. Be sure you lube it.
6. Tighten the WIF sensor on to the new filter.
7. Fill the filter and with #2, lube the FF gasket and reinstall.
8. Reconnect the WIF sensor wires and start her up. Check for leaks.
Hope this helps.
Old May 13, 2007 | 09:38 PM
thanks mike. sounds good. I can keep it from dying out but it's kinda embarrassing to have to keep cranking away in the parking lot.
Old May 14, 2007 | 05:23 AM
bow2no1's Avatar
i got my filter where is was almost in place and used one of those long funnels.
i think they are for transmissions?
filled it with diesel fom there.
Old May 14, 2007 | 08:38 AM
BOW, why would you not use the primer bulb? Just cut off a broom handle and pushing the primer button is easy.
Old May 18, 2007 | 12:15 PM
Phil, is this issue resolved? Please update.
Old May 18, 2007 | 05:01 PM
Yea I changed the filter and it didn't work. So I took it to williams diesel. The lift pump checked out alright so it's something in the ip. 900 dollars is the estimate for parts and labor. I'll lock it.
On edit: That is sweet. I love locking threads...now I see why you liked doing it doc
Old May 18, 2007 | 05:41 PM
Come here - I got something for ya...
Old May 18, 2007 | 07:52 PM
you ain't got nothing old man.
