black smoke!!!!!!!!!!!!!!
Old Dec 21, 2008 | 01:26 AM
smokedout's Avatar
Default black smoke!!!!!!!!!!!!!!
I need more smoke any ideas?
Old Dec 21, 2008 | 01:27 AM
DB Admin's Avatar
Banned
Injectors and DV's
Old Dec 21, 2008 | 01:31 AM
94cummins12v's Avatar
lots of fuel
Old Dec 21, 2008 | 10:05 AM
cummins24's Avatar
Wrap a towel over the air filter
Old Dec 21, 2008 | 11:34 AM
Diesel Dave 2's Avatar
Do the AFC adjustments all forward and and smoke will roll...Need more...Yes injectors and DV...Then turbo time because EGT will start to get crazy...
Old Dec 21, 2008 | 12:35 PM
SmokinPiney's Avatar
A stock plate full forward will not smoke all that much. Swap out that stocker for a #5 or better and you'll be chuggin in no time
Old Dec 21, 2008 | 12:56 PM
#5 was a good one for me then i went with a 0 make a little bit of difference but i have alot of upgrades that roll the coal
Old Dec 21, 2008 | 02:03 PM
smokedout's Avatar
whats the best plate for the most smoke?
Old Dec 21, 2008 | 02:11 PM
xzaq103's Avatar
FormerVendor
#0 or #100
Honestly why do you want it to smoke? Its gonna be hot but id say a good smoke setup would be 370s LCDVs and a gutted AFC.
In your situation I would grind the plate to a #100 and gut the AFC For smoke or Just Put the start wheel as loose as you can get it. This should give you plenty of smoke.
I dont see gauges in your sig do you have any?
This would work as well but im not sure it would start....
Old Dec 21, 2008 | 05:09 PM
jasonw's Avatar
Remove your turbo. Then when your pistons weld themselves to the block, take some pictures. I'd like to see the damage.
