Truck will not warm up.
Old Dec 15, 2008 | 05:46 PM
bonk's Avatar
Default Truck will not warm up.
I have a 94 Yukon with a 6.5L and the enging will not warm up. Temp gauge only comes up to second line on gauge. Have changed the thermostat and the fitting that comes off the water jacket. Have also changed the fan clutch as old one was locked up and wouldnt release. also changed heater core. Anything i am missing or any ideas what could be wrong.:argh:
Old Dec 15, 2008 | 06:23 PM
wildbill's Avatar
Maybe it's cold enough to where you have to block the radiator with cardboard.
Old Dec 15, 2008 | 07:30 PM
bonk's Avatar
Just put some in, Havent gone anywhere to see if it works or not yet. We changed the heater core cause there is very little heat in the cab.
Old Dec 15, 2008 | 07:38 PM
wildbill's Avatar
Don't worry about it overheating cruising down the highway/freeway empty if you forgot to remove the cardboard. Mine stays just below 200.
Old Dec 15, 2008 | 07:48 PM
bonk's Avatar
not worried about o/h right now. -45 celcius in the wind
Old Dec 15, 2008 | 08:18 PM
Patches's Avatar
i asume none of the coolant is dissapearing?
Old Dec 15, 2008 | 09:00 PM
bonk's Avatar
No none of the coolant is disappearing. The cardboard did get me one more line on the gauge. I still have the top half of the fan shroud off from changing the fan clutch this afternoon. Would that make a difference?
Old Dec 15, 2008 | 09:05 PM
wildbill's Avatar
It would a little bit, because the shroud helps the fan suck more air from the outside of the radiator to the inside.
Old Dec 16, 2008 | 10:05 AM
K50's Avatar
K50
Are you in N.Canada?
Old Dec 16, 2008 | 02:29 PM
bonk's Avatar
No i am in Regina.
