CEL is back
Old Dec 14, 2008 | 04:49 PM
Az2500Cummins's Avatar
Unhappy CEL is back
When I shut off my truck last night, I had no CEL. When I started it up this afternoon, the CEL was there, and I was blowing alot of white smoke. I know that means my truck is stuck in REGEN right? How do I stop it? The EGR is still plugged in.
Old Dec 14, 2008 | 05:08 PM
ETXBlueRam's Avatar
Have you pulled the codes?
Old Dec 14, 2008 | 07:00 PM
How do I check them? I forgot the sequence.
I tried to check it, it said P something, but it disappeared before I could read it all, and then it gave me 6 bars, then said Done.
Last edited by Az2500Cummins; Dec 14, 2008 at 07:00 PM. Reason: Automerged Doublepost
Old Dec 14, 2008 | 08:33 PM
ETXBlueRam's Avatar
Starting from the off position.. Turn the key to the on position(not far enough to start) then back off, three times, fairly quickly.. A "P" code is powertrain related. Once it has gone through the diagnostic sequence, you will see the word "done"
I still haven't found a comprehensive list of all the codes for the '08 yet. The list of codes I looked at here on the site, doesn't cover most of the ones I've had come up on mine.
Post what codes you had come up and if it's one I don't know, I bet somebody else will.
JB
Old Dec 14, 2008 | 08:50 PM
I will try again tomorrow.
Old Dec 14, 2008 | 08:54 PM
ETXBlueRam's Avatar
Let me know what you find.
JB
p.s. A little off the subject, I noticed your profile says you're in Killeen.. You at Ft. Hood?
Old Dec 15, 2008 | 02:40 AM
kcpanages's Avatar
try plugging the egr back in for a couple of days..... u are getting a soft code for the egr being unplugged wich is causing the regen.......... or it could be a problem with ur GEN II box...... herd badp is having problems with gen 2 box going into regen
Old Dec 15, 2008 | 08:11 PM
I never unplugged the EGR. I didn't have time to unplug the batteries. And yes, I am at Fort Hood.
Old Dec 17, 2008 | 06:39 PM
The code I got is P2426. Anyone know what that means?
I just read somewhere it is P242b, not a 6. Exhaust temp sensor circuit perf. WTF is that, and how do I fix it?
Last edited by Az2500Cummins; Dec 17, 2008 at 06:39 PM. Reason: Automerged Doublepost
Old Dec 17, 2008 | 07:11 PM
wildbill's Avatar
Sounds like a probe in the DPF is reading high, kicking the truck into regen.
