03-07 Cummins CR 24V 5.9L Tech Talk Tech articles for the 03-07 Cummins Common Rail 5.9L Engines.
3rd Gen Tech: Cummins Grill logo
Old Dec 7, 2008 | 12:58 AM
wildcat's Avatar
Default 3rd Gen Tech: Cummins Grill logo
I debadged my 2007 truck a while back, and have been trying to come up with something to replace the Dodge emblem on the front grille. I decided to put the Cummins “C’ on the grille.
This is what I came up with, and how I did it..
First, I had to cut of the “Turbo Diesel” part. I used a cut off wheel, starting from the back of the emblem low enough not to get into the actual “C”. It helps to put the “Turbo Diesel part in a vise to hold it.
This is what it looked like after cutting. Can’t stress enough to be sure you are low on the “C”, if you use this method, because the plastic gets hot and melts a little.
Next, I did some sanding and then some trimming with a sharp knife.
This is what it looks like.
I used some goo gone to clean up the back side of the “C”
Here it is cleaned up
Next, I removed the Ram emblem using fishing line. (10 Pound test)
Old Dec 7, 2008 | 12:59 AM
wildcat's Avatar
Default Continued
I then separated the Ram head from the black background piece. I used the knife to trim away the snap sockets so I’d have a flat surface to mount the “C”.
I cleaned the glue and sticker residue off the grille.
I masked off the emblem area, and began to paint it black. This will help blend the black background piece into the grille.
After a couple coats of Gloss Black
The “C” is flat, and the black background piece is curved a little, so I used a dark gray RTV to glue it to the black background piece.
I let the RTV dry overnight.
This is how it looks so far.
After letting it dry overnight (It’s not completely dry, but good enough to work with). I used the same RTV to glue it to the truck.
Here’s the finished piece.
Daylight pics:
As always, feel free to comment or ask questions!
Old Dec 7, 2008 | 02:57 AM
ride42's Avatar
Looks badass, try getting a shot from the front about 4' out looking towards the grill.
Old Dec 7, 2008 | 04:03 AM
wildcat's Avatar
found the pics and put them in for you!
Old Dec 7, 2008 | 01:02 PM
ride42's Avatar
That is good looking, looks a lot better than the ram head.
Old Dec 7, 2008 | 01:44 PM
mishkaya's Avatar
Sweet!
mishkaya
Old Dec 8, 2008 | 05:15 AM
wildcat's Avatar
To the top for the morning crew!
Old Dec 8, 2008 | 07:29 AM
GRI's Avatar
GRI
cool!
Old Dec 14, 2008 | 07:58 PM
7.3 Cowboy's Avatar
Old Dec 14, 2008 | 08:53 PM
Camotanker's Avatar
no offense... but you turned on the little "flower" on your camera when trying to take detailed up close shots, it will not be blurry and you will get the killer shot you are going for.
