Official Getting Ready For Winter Thread!!!
Old Nov 22, 2008 | 10:17 AM
Buckshotmckee's Avatar
Sma't Alec!
Smile Official Getting Ready For Winter Thread!!!
Alright guys and girls! Post up your helpful hints/ideas/BOMBs to get ready for the winter months!
https://www.dieselbombers.com/5-9l-c...elocation.html
https://www.dieselbombers.com/5-9-li...e-my-6spd.html
Old Nov 22, 2008 | 10:20 AM
DB Admin's Avatar
Banned
Cold Weather Fronts
https://www.dieselbombers.com/baseme...er-fronts.html
Old Oct 11, 2009 | 12:06 AM
up 10's Avatar
If you have a set of tire chains, make sure they fit before you actually need them, make sure you know how to put them on. P.S. you dont need a jack or lay them out on the ground driving on to them, its sillyness, drape them over the tire then roll forward and hook the ends. Every year in the oilfield I'm amazed at the people who dont know how to put chains on and the things they try. Get under your truck and check for any wires hanging down that may be damaged by collecting road ice. After washing your truck in cold weather spray your door seals with WD-40 to keep your doors from freezing shut If your windshield wipers seem to skip over certain areas or ride over the slush and snow, try some shorter wipers Plug it in, especially if you plan to keep your truck for a long time, save your engine the cold start damage Carry a tow strap, cold weather clothing, gloves, shovel, ect. the *** you save may be your own, I also carry a set of tow truck style frame hooks for pulling cars with plastic bumpers Be safe have fun
Old Oct 11, 2009 | 12:19 AM
wildbill's Avatar
Don't rely on anti-gels, especially when it gets below 0. Run at least a 50-50 mix of #1 and #2. Carry an extra fuel filter in case you do gel up.
Old Oct 11, 2009 | 09:16 AM
Sma't Alec!
Power Service & Amsoil are making a gel solution that after the fuel gels your suppose to be able to add this stuff and it clears up the gel so the truck will run/start.
Old Oct 11, 2009 | 10:12 AM
wildbill's Avatar
Only thing about Power Service 911 is that it has alcohol in it.
Old Oct 11, 2009 | 12:01 PM
dustys24valve's Avatar
Howe's Lubricator is good for anti-gelling also, but it can be run all year. It helps keep everything clean and keeps things better lubricated than the low sulfer diesel alone.
Old Dec 4, 2009 | 09:39 AM
stevenbrazell's Avatar
dang yall, here in texas we dont have that problem, haha. but its 25 right now here in college station
Old Dec 4, 2009 | 10:26 AM
Gerry's Avatar
here in california we have to make sure the AC is working... some days it gets up in the 90's
Old Dec 4, 2009 | 11:19 AM
ArizonaRedneck's Avatar
make sure you carry an emergency stash of goodies that will help you make it through a stranded situation and make sure you carry enough for any texans or californians you might run into
