idk what this does...
Old Nov 5, 2008 | 10:56 PM
Big_Johnson's Avatar
Default idk what this does...
what would it do iif i got rid of the 6.6L thing in my truck? What's it called the resonator? and how much is it to do?
Old Nov 5, 2008 | 10:58 PM
wildbill's Avatar
Dmax owner will chime in!!
Old Nov 5, 2008 | 11:01 PM
2500HeavyDuty's Avatar
i would guess you have the engine cover with the hose on it?
Old Nov 5, 2008 | 11:24 PM
uwyo_dmax's Avatar
I took mine of a while back its supposed to give you a little more turbo whistle is what they say. Some say quicker spool up. Its real easy just plug the hole in the intake with a 2 1/2 quick plug i got one from home depot.
I would say i maybe got some more whistle, but for $3 its worth a try.
Old Nov 6, 2008 | 12:24 AM
alright thanks. sounds good i might give it a try.
Old Dec 7, 2008 | 04:24 PM
bhiland23's Avatar
I have mine off. Just plug the hole and your fine. It doesn't need to be on the truck.
Old Dec 7, 2008 | 04:27 PM
i keep mine on, i hides things. but its the slim plastic cover with out the resnator.
Old Dec 7, 2008 | 05:44 PM
bigdaddydiesel's Avatar
Be sure to check the plug every other month and lube it with vasoline or something, I have heard horror stories of the rubber in the plug dry-rotting and coming apart and allowing pieces to enter the turbo.
Old Dec 7, 2008 | 07:32 PM
RodZZilla's Avatar
WhiskeyRiver took my mind
I put a cap on mine. Less likely to get something dropping in.
Old Dec 7, 2008 | 10:51 PM
i just took a pvc cap and turned it upside down and shoved it in the hole. it stays and i haven't had any problems with it yet.
