99 Dodge 2500 wont shift
Old Nov 1, 2008 | 04:09 PM
Rdwwyo's Avatar
Default 99 Dodge 2500 wont shift
I have a 1999 Dodge 2500 diesel with the auto and it seems like its in limp mode. I tried the resistor on the orange wire, and it didnt work. I just got this truck on Wed. 183K miles are on it. I need help. Does it sound like a bad transmission? May need a tranny flush? Any ideas would be appreciated. What transmission company would be the best?
Thanks
Rick
Old Nov 1, 2008 | 04:32 PM
busta's Avatar
I had my govenor pressure soleinoid replaced recently as mine won`t not shift sometime
might take it to a tranny shop near you and have em hook it up to their scanner
mine would not show any codes but theirs did
good luck
Old Nov 1, 2008 | 04:50 PM
Rdwwyo's Avatar
Thanks. I need to call a local shop and get it in. I can pull the battery cables and it seems like it will shift fine.
Rick
Old Nov 6, 2008 | 02:40 AM
Queeg's Avatar
Rick
Or get in touch with dave goerand! He is a magician with the 47 re trannys! Got mine to work for 6 months! Yes it was a bandaid till I could afford a new trans, but I am hard on my trans everyday!
Old Nov 6, 2008 | 08:55 AM
feroxman's Avatar
I once had what sounds like the same issue with 99. I called all over the place and got the same suggestion several times. Clean the battery cables.
If your cables are clean, you may want to look to the injection pump. Mine went out at about 185k.
nelly559
Feb 2, 2015 08:19 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
