Street And Track Racing Diesel Discussions of Street And Track Racing Practices , Techniques , Tips and Kill Stories PLEASE BE CIVIL
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
my truck is friggin slow..help me....
Old Oct 31, 2008 | 01:23 PM
dieselbeef's Avatar
Default my truck is friggin slow..help me....
super b, 130 hp inj, intake horn, airaid, drag comp on 5x5, smarty on #8, 4.10 gears w 35's ran a 16.05. 2.15 60 ftr........im so ashamed......
last time w/o the turbo ,inj and 33's i ran a 17.60....that was really pathetic
any 24v guys got any ideas......slower than i thought it oughtta be. makin bout 35 psi...runs good and strong but just dont git after it hard enuff.....trannys good
Old Oct 31, 2008 | 02:47 PM
SeaDrive's Avatar
2.15 60ft indicates a pretty slow take off. Are you doing a 4WD boosted launch? Is that turbo lighting quick enough? What RPMs you turning at the finish line? Doesn't sound right. I've never run my truck but I used to do a lot of bracket racing and I don't have 1/2 of what you got in your truck and I guarantee I can hit a high 15 in my truck (well after I get a tranny that is).
Old Oct 31, 2008 | 04:28 PM
kazairl's Avatar
Well something isn't right. Even with a 2.6 60' I can still run a 16.1 at 88MPH. and that was with just an Ez and my injectors. with a six speed to boot. Like ^ said are you doing a boosted launch in 4wd? To my mind 35PSI is a little low with the fuel your putting to it. Maybe your wastegate is opening too soon?
Old Oct 31, 2008 | 04:33 PM
Pack Mule's Avatar
NITROUS and a 3rd gear boosted launch. with th e4.10's you're not gonna be very fast. find someone to swap you for some 3.54 and you'll pick up a bunch i promise. you should be in the 14's. what clutch are you running??? what's your charger measurements??
Old Nov 1, 2008 | 11:30 AM
dieselbeef's Avatar
i got 35's w/4.10's...boosted 20 psi launch..4wd. i was about 89 mph top end
i just swapped out the 3.55 for 4.10 actually cuz i do so much towing
Old Nov 1, 2008 | 02:57 PM
kazairl's Avatar
Is your tranny stock or aftermarket? I would start looking at that next I think. For a boosted launch you should have a faster 60' time than that.
Old Nov 2, 2008 | 05:53 AM
dieselbeef's Avatar
triple disc. full comp parts cept for the valve body. revs dont skyrocket when it leaves. it aint slippin. torque mangemant under smarty control
Old Nov 2, 2008 | 06:42 AM
MoPower05's Avatar
That torque converter could be slipping. My triple disc only lasted 9 months. So just because you have aftermarket transmission parts dont over look that as the problem.
Old Nov 2, 2008 | 07:29 AM
2001shrtbedcummins's Avatar
Sounds like a boost leak, or a weak injector pump.
Old Nov 2, 2008 | 08:22 AM
dieselbeef's Avatar
if the pump was weak would it smoke like a steam engine....but im gonna look into the boost leak
