6.5 TD into an 85 Yota
Old Oct 30, 2008 | 08:14 PM
Grim Reaper's Avatar
Default 6.5 TD into an 85 Yota
ok, so i need to start a different project and get away from my black truck cuz im breaking to many dang things here lately! .. i had a friend give me a 93 model 6.5 turbo diesel from his old wrecked chevy. i have a toyota truck that i lifted a little bit and i want to really jack it up in the future, and in doing that i need something with a little more power and something that gets a little better mileage than the little 22r in it already.. has anyone on here done this conversion yet? im curious if so id like to know just a few pointers on what to watch out for and what not..
Old Oct 31, 2008 | 09:13 PM
RSWORDS's Avatar
You are asking for axle problems. The front IFS is weak with the 22r in it I dont see it holding up to a Diesel. So figure that into the project cost because you WILL have to upgrade the axles.
Old Nov 1, 2008 | 02:21 PM
gunman41mag's Avatar
Moderator
The TOYOTA truck your talking about with thr 22r, is the little one, if so you better have a MONEY MACHINE, cause your going to have to change almost everything, I know a guy who put a 5.9 CUMMINS in his LAND CRUISER, but that SUV has some room for the engine !!!
Old Nov 1, 2008 | 08:32 PM
RSWORDS's Avatar
I don't think the 6.5 is much bigger then a 350 is it? We put a couple 350's in yotas around here and its not too bad as far as swapping engines goes. The rest teh truck is not up to the task. Maybe look at a stock 4bt.
Old Nov 3, 2008 | 12:30 AM
yeah the 6.5 is just a hair bit bigger than a 350, but everything mounts the same and you can swap trannys and whatnot from big blocks small blocks to the 6.5.. the yota i have has straight axles, it was the last year of the straights...
Old Nov 5, 2008 | 10:12 PM
Rocky Mountain Texan's Avatar
i'm doing the same thing to an 87 toyota except i'm dropping a 1st generation 12 valve ctd in it
Old Nov 6, 2008 | 07:34 AM
RSWORDS's Avatar
At least it is better then the IFS but the Burfield will not take any abuse in a lock turn position. Get a set of longfields that will help them. Is teh 4cyl EFI? If so DONT swap. That truck is worth a good chunk of change over KBB.
Old Nov 6, 2008 | 10:26 PM
ok cool.. no, the 4 banger in this truck is still carbureted..
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
