My PPE Boost Increase Valve
Old Oct 29, 2008 | 07:35 PM
Big_Johnson's Avatar
Default My PPE Boost Increase Valve
So i was told i should do a write up of this. But it's the first think i've ever done on my own so i'm just going to tell you what i did.
First i had to remove my 6.6L cover which was kinda hard cuz the guys at the dealership tightened it a little too much. I ended up just pulling it off which didn't break anything so i'm guessing it's okay.
then i found the hose that goes from the wastegate to the turbo.
then cut about 3/4" out of the center of the hose. I actually use just a piar of sharp garden shears to cut the hose. That will be the amount of space you need to fit the increase valve. when putting the the hose in be sure that the arrows are pointing towards the wastegate. After that instal the clamps on each side of the Boost increase valve and you should be good. I wish i had take pictures as i was doing all this but i kinda didn't think about it and it was pretty dark when i did it. but here is the finished project...
i'm pretty proud of myself since it's the first thing i've done.
Old Oct 29, 2008 | 10:44 PM
toy4xchris's Avatar
good stuff how do you like it so far? I did mine with a list of other stuff so not really sure how much it did for me.
Old Oct 29, 2008 | 10:54 PM
i've only drivin it a little bit since i've put it in. and it's kinda hard to tell on acceleration cuz like the cops are crackin down since it's the end of the month. i actually got a ticket in my neighborhood today.
but i think my turbo is a little louder. and it seems a little faster. but i like it.
i'll have some type of programmer and gauges soon so i'll know how much boost i have.
Old Oct 29, 2008 | 11:22 PM
2500HeavyDuty's Avatar
stock boost is around 22 psi, i made 25 stock idk why. but now i make 30
it does let the turbo spool a little quicker
Old Oct 30, 2008 | 12:03 PM
Oilfield_Mafia's Avatar
Good job Bud
Old Oct 30, 2008 | 03:31 PM
cdennyb's Avatar
Default here' mine...
Don't beat me up 'cause I drive a Dually Ram 3500 with the cummins. Although this worked fine on my turbo I'm sure you guys running the Fords and Chevys have the same situation on the boost thing.
The pressure regulator I made to make sure my waste gate stayed shut until a predetermined psi then the reg opened and started actuating the waste gate diaphram.
Works like a charm. I too was only getting 25-27 psi of boost max and after this little mod, I was able to peg 30 psi no problem.
I tried to get the pics uploaded but couldnt get the pop up window to work that allows me to select the pics on my drive, so PM me if you want to see 'em.
I'll try to upload in a second posting.
db
Old Oct 30, 2008 | 03:42 PM
toy4xchris's Avatar
dont worry about being beat up man I got a cummins also I am just trying to get rid of it
Old Oct 31, 2008 | 12:01 AM
db
i tested out using an air pressure regulator on the waste gate line, worked alright
Old Nov 14, 2008 | 12:17 AM
uwyo_dmax's Avatar
Can you run this with big tunes, i to can hit 24-25 pretty easily right now without it. If i put it on is it going to raise it to much?
Old Nov 14, 2008 | 12:30 AM
i was making about 27 before i put mine on, now i am making 30 with the same tune.
