Vehicle Speed Sensor question
Old Oct 20, 2008 | 02:46 PM
autumqueen's Avatar
Default Vehicle Speed Sensor question
Have a 92 Dodge D-250 Truck. Had VSS replaced 9-06. Had it replaced 4-08. Took back in Friday and they replaced it yet again. The dealer mechanic says they checked all electrical and the main board and all is fine. When dropped off on Friday took through car wash to demonstrate symptoms. Drove out of car wash alternator gauge and speedometer gauge was bouncing all over. If the cruise control works the overdrive works. Cruise control pretty much stopped working and so did overdrive. This usually occurs when it rains, or you go thru a carwash. Will be picking it up tomorrow. Any suggestions as to what is eating up the VSS's would be appreciated.
Old Oct 26, 2008 | 12:54 PM
MRaynor's Avatar
Old Oct 26, 2008 | 02:55 PM
Whit's Avatar
Site Mascot
any and all connections for the VSS need to be pulled apart and cleaned with electric contact cleaner then blowed out with air then use some dialectric contact goo on it when ya put it back together
Old Nov 13, 2008 | 02:22 PM
MRaynor's Avatar
Any updates?
Old Dec 10, 2008 | 12:59 PM
wildbill's Avatar
Sounds like they need to design them better as far as waterproofing the connection. Like Whitmore said, contact cleaner, then dielectric grease.
Old Dec 10, 2008 | 01:35 PM
1stgenman's Avatar
Hey just like they said but if you want to be extra save i would wrap the connection with some electrical tape when its all back together.
Old Dec 16, 2008 | 08:59 AM
wildbill's Avatar
Any updates?
Old Dec 22, 2008 | 08:05 AM
wildbill's Avatar
Sounds like the issue has been resolved. Thread starter can reopen.
Aug 27, 2015 05:50 AM
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
F250MACH
Apr 26, 2015 05:19 PM
Oct 27, 2014 08:10 AM
