Blower motor?
Old Apr 30, 2007 | 09:49 AM
pipe539's Avatar
Default Blower motor?
I was driving home Yesterday from Wheeling and I was noticing that the A/C blower was making alot of noise but not putting out alot of air flow. Is there a cab filter in these trucks like the Chevs do? I didn't sound like there was anything broken just loud. I was Hauling a truck camper and towing a Jeep on a trailer if that makes a diffrence.
Old Apr 30, 2007 | 11:34 AM
Heath's Avatar
Authorized Amsoil Dealer
I don't show a cabin filter in my books. Wish they did though.
Old Apr 30, 2007 | 11:48 AM
Uncle Bubba's Avatar
You can get a cab filter through Geno's but they don't come factory with one. Sounds like your losing your blower motor. Bearings are probably going out. Some folks drill a little hole in the housing and shoot some WD40 in there and it may prolong the replacement. Once they put enough drag on the motor then it will also blow the resistor, that's another $50 to add on. I went through 3 resistors before I finally figured out that the fan was bad.
Old Apr 30, 2007 | 12:08 PM
pipe539's Avatar
The motor sounds like its spinning but it just not giving the air flow. example the flow is like on the slowest setting when set to high. I can hear a change in speed when i change speeds and when in hi the fan sounds like it is really a ripping but no flow, I'll have to check it out better. I was hanging and tired driving yesterday. BTW finished my trailer last week tows great.
Old Apr 30, 2007 | 12:19 PM
CHenry's Avatar
Vegistrokin Bombardier
sounds like you have a blockage between the fan and the outlets....does the air comming out smell like mouse poo?got a critter nested up in there?
Old Apr 30, 2007 | 01:17 PM
It's an easy project to pull the fan and check it all out. Just a couple of screws and unplug the wire bundle. This would also give you some room to check for blockages.
Be sure and post photo's of the trailer.
Old May 2, 2007 | 05:57 PM
pipe539's Avatar
No, No mouse smell, But i do think there is some kind of blockage. still working on it.
Old May 7, 2007 | 01:51 AM
pipe539's Avatar
Problem seemed to fix it self now. I'll have to keep an eye on it.
Old May 7, 2007 | 08:04 AM
Whit's Avatar
Site Mascot
the lil door that diverts air flow tween floor windshild or dash is vacumn operated and may just be stuck in one position
Shun70
Sep 20, 2015 10:52 PM
Aug 7, 2015 12:40 AM
woodsmen
Diesel Engine Conversions
Feb 9, 2015 08:37 AM
Dec 3, 2014 09:40 AM
Nov 19, 2014 01:40 AM
