Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
1ST 500 miles towing 50 mph less?
Old Sep 20, 2008 | 10:42 PM
bowhunter8's Avatar
Default 1ST 500 miles towing 50 mph less?
Truck Manual says that the first 500 miles of towing you should drive 50 mph or less. How many have stuck to this and who has not? Any problems.
I will be picking up my gooseneck in Ball Ground, Ga. it will be loaded at 14,000.
Thanks for any help.
Old Sep 20, 2008 | 11:03 PM
wildbill's Avatar
It's because the engine tolerances are still tight, especially the top end. Break it in right and it'll last a long time.
Old Sep 20, 2008 | 11:17 PM
bowhunter8's Avatar
Thanks wildbill
Old Oct 16, 2008 | 04:09 PM
nmlakerat's Avatar
I with all engines i build run them not at a constant speed but very your speed dont just set the cruise at 50 and let her ride
Old Oct 18, 2008 | 08:24 AM
jim w's Avatar
I have read on other sites the rear end mainly "the gearing needed to be broken in" to the tow load that is being placed on it. I do not know if this is true or not but I did follow the O and M manual and did not tow above 50 MPH. I also very the spped of the truck on the highway but more important I made sure that I did not leaving the engine RPM in the same speed range. I keep my eye on this and made sure the RPM did not stay at one reading very long. I also did not tow in 6 Gear (auto) Keep the RPM's in the 1800 to 2000 range. With the tow haul mode on and the EB on.
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
