Installing 4" DiamondEye Exhaust
Old Sep 10, 2008 | 07:54 PM
blueridgeshepherds's Avatar
Default Installing 4" DiamondEye Exhaust
Hello all! I am new here so I hope I am starting this post off right. My question is common to most exhaust system replacement for later model trucks. I have 95 Chevy 6.5 duramax that I am currently removing the factory exhaust and installing a new Diamond Eye 4" exhaust system. While trying to remove the rusty bolts from the factory crossover pipe, most of them broke leaving part of the bolt in place. Has anyone got an easy solution to removing these? I would appreciate any suggestions.
Thanks
Old Sep 10, 2008 | 08:03 PM
Benjamin's Avatar
Bombardier
you can spray it down with PB Blaster and let it sit for a while. go to the parts store and get a stud remover. this works if you have more than 1/2-3/4 inch of bolt sticking out. if not you will have to drill it and replace it with a nut and bolt.
Old Sep 10, 2008 | 08:04 PM
wildbill's Avatar
Little heat and a penetrating catalyst like PB Blaster. Weld a couple nuts on the studs, if possible, that way you can get a breaker bar and socket on em to help work em a little better while heat and oil is being applied.>>>>>>BTW, welcome to to DB!!!
Old Sep 10, 2008 | 08:09 PM
Benjamin's Avatar
Bombardier
thanks wildbill i forgot about the weld a nut to it method. i had to do that on my expedition on the exhaust manifold bolts
Old Sep 10, 2008 | 08:12 PM
wildbill's Avatar
Old Sep 10, 2008 | 08:20 PM
Thanks guys, I will give that a try.
Oh, and thanks for the welcome also!
This is my first diesel and I have been doing alot of research on the needed upgrades, the 4" exhaust is my first upgrade, next will be to relocate the PMD and add the cold air intake.
Last edited by blueridgeshepherds; Sep 10, 2008 at 08:20 PM. Reason: Automerged Doublepost
Old Sep 10, 2008 | 08:29 PM
wildbill's Avatar
I don't believe you got a D-Max in her. 6.5 is still GM, but has a little Banks mixed in.
Old Sep 10, 2008 | 08:30 PM
Benjamin's Avatar
Bombardier
cool deal. post up an introduction thread HERE and tell us about you and your truck.... pictures are definitely a plus
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
virgil47
Chevy/GMC Duramax 06-07 LBZ
Oct 11, 2014 12:32 AM
