Fuel Plates
Old Sep 8, 2008 | 03:00 PM
Dieselsmokin's Avatar
Default Fuel Plates
i thought i read on here somewhere that someone had listed specific horsepower ratings with all these ground fuel plates...is there such a thing? ...if so great! ...could someone lead me to these...if not...can anyone tell me what they are or how i can expect my truck to run with each different plate? i currently have a Banks plate in it now ...moved it forward from the stock position but still doesnt feel as though i've got enough power there. The low end has increased quite a bit ...but the mid range is not as good as the stock position. Is there a plate i can trade it out with that will get me the most power that i'm gonna get from it by just changing the plates? what can i expect from bumping the timing up? i just changed the banks air filter out and replaced it with the BHAF and pre-filter. any help appreciated
Old Sep 8, 2008 | 03:08 PM
DB Admin's Avatar
Banned
This may Help you
https://www.dieselbombers.com/12-val...-profiles.html
Old Sep 8, 2008 | 03:19 PM
xzaq103's Avatar
FormerVendor
Is your trans stock? A #100 or #0 will give you a lot of fuel but without trans mods your just asking for trouble. If i remember correctly you can’t grind a banks plate into #100 but you could grind it to a #0 and not put it at full forward. I have also heard some trucks seem to make a little more power with the plate just a little shy of Full Forward. You might try that as well.
Bumping timing will get you slightly better mileage, a little more top end and if I remember correctly it will lower egts slightly. It will also be a little louder and you might notice a slight loss of low end power.
Old Sep 8, 2008 | 06:09 PM
DM.... in the link to the fuel plates you listed there is an additional link to "PDR camplate horsepower guide" but the page has been removed...any chance that it can be found any other way??
Old Sep 8, 2008 | 06:22 PM
DB Admin's Avatar
Banned
PDR Diesel Inc. The turbo diesel performance specialists! - Camplates
Old Sep 8, 2008 | 07:22 PM
TST Products originated the modified fuel pate - theres also more info here:
http://www.tstproducts.com/94-98dodg...withvideo.aspx
This is now considered to be just a guide. There lots of people grinding their own custom plates and getting them from other sources.
Bumping the timing will give you a very marginal bump in hp - but, more importantly it will make the truck run better. You should be somewhere between 15-17 degrees.
For some extra performance you should look into a 3k or 4k Governor Spring Kit.
Also, have a look at this:
https://www.dieselbombers.com/5-9l-1...-12-valve.html
Old Sep 9, 2008 | 11:34 PM
Cameron's Avatar
is there any truth to sticking with a 3k gsk on an auto and a 4k to man.
Old Sep 9, 2008 | 11:36 PM
DB Admin's Avatar
Banned
The 3K dont Require Valve Springs the 4K Do
Old Sep 10, 2008 | 12:23 AM
LOTS of guys running 4K springs with autos. I cant recall hearing that before.
Old Sep 10, 2008 | 12:25 AM
DB Admin's Avatar
Banned
Yeah ive never heard of any different on the auto or manual i was just stating that the 4k's require Valve springs
