Help Codes
Old Sep 5, 2008 | 07:50 AM
firecapt870's Avatar
Default Help Codes
can anyone tell me what thies codes are for a guy that i work with has a 2006 dodge cummins and his check engen lite is on and these are the codes we got P0217 AND P2509ANY HELP GUYS AND WHAT MIGHT BE THE FIX. THANKS
Old Sep 5, 2008 | 08:12 AM
Oilfield_Mafia's Avatar
Hey Firecapt, I couldnt find the 2nd code right off hand, Lemme do a little bit of research to see what I can find out. For now, this is the results of the first code..
PO217 : Decreased Engine Performance Due To Coolant Overheating
Lemme see what I can find real quick to help you out.
Ok I found a definition of the 2nd code:
P2509 ECM/PCM Power Input Signal Intermittent
So Far it looks like the P2509 could mean weak or dead cells in one or both batteries. But thats not definate yet. Im still looking.
Lemme see what kinda coverage I can find explaining what they mean and possibly how to fix them.
Last edited by Oilfield_Mafia; Sep 5, 2008 at 08:24 AM. Reason: Automerged Doublepost
Old Sep 5, 2008 | 08:13 AM
Jazz's Avatar
Here you go Bud for future reference https://www.dieselbombers.com/codes.php
Old Sep 5, 2008 | 08:31 AM
I cant seem to find a straight answer on what causes the P0217, or how to fix it.. All we know for sure is that its set by Engine coolant overheating.
Hope this helps you in some way!
Old Sep 5, 2008 | 09:21 AM
wildbill's Avatar
P0217:
2. ECT SENSOR
Allow the engine to reach normal operating temperature.
Use a temperature probe and measure the engine temperature near the ECT Sensor.
With the scan tool, read the Engine Temperature.
Compare the temperature probe reading with the scan tool reading.
Are the readings within 10° of each other?
Yes >> Repair the cause of mechanical failure.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC
CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
No >> Replace the coolant temp sensor.
The temp sensor is on top of the engine, next to the thermostat housing.
Old Sep 17, 2008 | 08:58 AM
Johnny Cetane's Avatar
Did you get this one fixed yet?
Old Sep 24, 2008 | 11:50 AM
Closed due to lack of activity. Will reopen later if needed.
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
