6.5 Fuel Pump Injector Repl. Questions
Old Sep 2, 2008 | 08:04 AM
imabeliever1's Avatar
Default 6.5 Fuel Pump Injector Repl. Questions
I am helping my son in law do some work on his 94 GMC w/ a 6.5 engine.
He bought a rebuilt inject. pump and injectors which we have replaced. They also sent some "fuel return" lines . These have the braided cloth exterior .
My questions are:
a. Is there supposed to be a gasket between the turbo and the exhaust manifold? There was not one and it did not appear to be leaking.
b. On the rubber fuel return lines that leap frog from injector to injector, the supplier said that with this line the spring clamps were not necessary because the pressure was low on these hoses. Is this correct?
Any other pointers on this install appreciated. First diesel I have ever worked on here, so you help would be much appreciated.
Thanks
Robert
Old Sep 2, 2008 | 08:53 AM
wildbill's Avatar
Question a) GM used paper gaskets and more than likely they blew out. I did the same thing, and that was "86" em
Question b) Hoses actually fit tight on the barbs and they don't need the clamps
Bill
Old Sep 2, 2008 | 03:09 PM
Default 6.5 injector pump
Bill.
Thanks for your reply concerning the gasket and the hoses. My lack of experience with diesel engines cause me to second guess everything
My concerns with the hoses are that they could leak or blow off (FIRE HAZARD!!!) and it would be a bear to remove the turbo "again" and fix the ones on the passenger side. Same for the exhaust gasket.
Thanks again for helping to calm my fears!
Robert
San Antonio, Texas
Old Sep 2, 2008 | 03:15 PM
wildbill's Avatar
This may help a little more. My dads 6.2 is the same way as far as the return lines. Takes a little bit to push em on, but a little engine heat then seals the deal. Takes even more to pull em off afterwards.
Old Sep 3, 2008 | 04:48 PM
Default Another Wild Bill question
Bill,
I have a request. Please email me off list as I cannot yet send private emails here yet. I have a couple of things I would like to run past you . Email address below.
No hard feelings from me if you do not care to.
Thanks
Robert
robertbox@hotmail.com
Old Sep 3, 2008 | 05:30 PM
wildbill's Avatar
Message sent!!!
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
