Need A Pinion Shim
Old Aug 7, 2008 | 04:43 PM
Uncle Bubba's Avatar
Default Need A Pinion Shim
Where can I find pinion shims that will fit our Dana 80 axles. I need a 2-3 degree shim in mine now.
Old Aug 7, 2008 | 07:55 PM
94cummins12v's Avatar
any napa or shucks or auto zone would have them
Old Aug 7, 2008 | 08:02 PM
I've tried everyplace I can find and even ordered a set from Summit that was labeled as 3 inches wide. Now that they are in my hands they are only 2 1/4 inches wide.
Everyplace I have talked to sells them for the 2 1/2 in wide springs, even the ones listed as for the Cummins are mislabeled just like all the poly fittings for these springs.
Old Aug 7, 2008 | 11:42 PM
Youre not supposed to buy these parts - your supposed to buy a new truck...
Old Aug 8, 2008 | 12:38 AM
I already have a few times over with what I've got in this one.
Old Aug 9, 2008 | 09:41 PM
With all the lifted trucks out there, what are you guy's using to correct your pinion angles since I can't find shims anyplace.
