Powerstroke Fuel Leak
Old Jul 27, 2008 | 02:37 AM
norm's Avatar
Default Powerstroke Fuel Leak
Hey, I just developed a fuel leak that drips near my passenger front tire after a service and now it is very wet under there and cannot trace without ripping stuff out. too wet. any ideas?
Old Jul 27, 2008 | 07:34 AM
sidekick's Avatar
what year
Old Jul 27, 2008 | 07:51 AM
2500HeavyDuty's Avatar
what kind of service did you get
Old Jul 27, 2008 | 09:29 AM
slowtowpig's Avatar
if it was a fuel filter some times you will get alot of fuel spillage and it will run into the valley and if you park on an incline it will drip down to the ground...
if its a pre-99.5 powerstroke it could be that you fuel pump is leaking, or the two blue hoese below the fuel fuel houseing is leaking, all are very common on the early powerstrokes.
Old Jul 27, 2008 | 01:11 PM
dmaxjenn's Avatar
IT'S A GIRL!
This thread should be moved to Diesel in distress post.... but welcome to the site..anyhow,.
Old Jul 27, 2008 | 07:49 PM
DB Admin's Avatar
Banned
/me moved thread
Old Jul 27, 2008 | 08:15 PM
thats what im guessing, from his info his is a 01 PS
Old Jul 27, 2008 | 08:28 PM
tony ramsey's Avatar
There is a valve on the back side of the fuel filter [on top of engine]that allows you to drain the fuel bowl when changing the filter. Check that relief valve making sure it's closed all the way............. When open fuel will drain exactly around the inside of passenger side front wheel, there is a tube that this fuel comes from. also be sure it's not fuel left from the service you had done setting on top of the intake.....tony
Old Jul 29, 2008 | 04:07 PM
slowtowpig's Avatar
dfuser.com sales a new water/fuel drain valve...
Old Aug 8, 2008 | 12:03 AM
Closed due to lack of response.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
cutthroatxxx
Dec 30, 2014 05:59 AM
Dec 5, 2014 08:30 AM
